Page 14 - MetalForming May 2011
P. 14
CMM Glides into Air-Bearing Manufacturing
Professional Instruments (PI),
a Hopkins, MN, manufacturer of air-bearing spindles and slides, recently was subcontracted to manufacture critical parts for the
Mars rover. To ensure its meas- urements (using a bore gauge,
gauge blocks and Mikrokator)
were on track, the firm partnered
with one if its suppliers, Andrew
Tool, which used its coordinate- measuring machine (CMM), a
Zeiss Accura, to check its key
parts. Soon after, PI went in search of its own CMM, to allow
it to, inhouse, measure critical air- bearing diameters. Holes are
sized down to 0.25 microns to
match shaft diameters, held to the
same precision, on a line of air-bearing spindles. A CMM also was needed to measure tapers on a new hydrostatic bearing being developed. Tests per-
formed at nearby Carl Zeiss Industrial Metrology in Maple Grove, MN, showed that the standard deviation with a Zeiss CMM for a 1.5-in.-dia. hole was approx-
imately three times better than the firm’s previous meas- urement methods.
Following the tests in 2009 the firm purchased a Carl Zeiss Contura G2 direkt CMM, boasting a maximum meas- uring rate of 150 points/sec. and a maximum sensor exten- sion of 100 mm. “This was the perfect system for our unique hole-sizing application, and at an affordable price,” says PI vice president Dave Arneson. The CMM measures the spin- dle hole size after grinding and typically measures 50 to 100 parts/day. Hole sizes are fed into a proprietary program
that matches the shaft to a correspon- ding hole to achieve the required flying height for the spindle.
“For our 38-mm-dia. measurements,
Solutions in scrap management.
At OmniSource, we take great pride in supporting our scrap-generating customers with customized solutions— solutions developed over decades of using the most-advanced technologies and reporting tools available. We provide world-class service to a varied customer base throughout North America, from the smallest scrap generators to some of the largest manufacturers. Our comprehensive reporting, strict adherence to environmental standards, and proven financial strength give you peace of mind that you’re partnering with a leader in the recycling industry. Call us—we’ll find a solution that’s right for you.
Any Metal. Anywhere. Anytime.
www.omnisource.com
For more information contact
Steve Bardon
sbardon@omnisource.com (260) 423-3950 office (419) 392-2360 cell
7575 West Jefferson Boulevard Fort Wayne, Indiana (800) OMNI-789
12 MetalForming/May 2011 www.metalformingmagazine.com
