Page 25 - MetalForming June 2011
        P. 25
MetalForming/June 2011 23
 deflection, to ensure dimensional accu- racy and repeatability, and provide long tool life. A large daylight and throat depth accommodates large dies, and long stroke lengths are adjustable from 1to18in.
One Press Replaces Three
“With the addition of the Greenerd press,” says Tipton, “we significantly increased productivity in several ways. Its adjustable stroke length and ton- nage capabilities provide us with tremendous versatility. Due to the large 18-in. stroke capacity, we’ve been able to standardize our dies and replace three mechanical presses–30-, 25- and 60-ton models–with the one hydraulic press.”
Also, according to Ilsco, press setup time has been reduced by as much as 85 percent. The press features prepro- grammed controls with stored part numbers and recipes. A removable press table allows operators to quickly and easily drill and tap tool-mounting holes or to resurface the table.
The Ilsco team also has discovered several benefits it never counted on when it purchased the hydraulic press. For example, when forming copper on a mechanical press, the material often fractured. The hydraulic press solved this issue by producing a more even, constant pressure throughout the stroke. The firm expects that this capa- bility will likely lead to more projects being transferred to the hydraulic press, including the manufacture of com- pression lugs, which also present mate- rial-flow challenges when formed on mechanical presses.
The hydraulic press produces some 15,000 specialty connectors/month and, once Ilsco completes the transi- tion of its dies to the Greenerd press, it expects production to double within 6 months. MF
Article provided by Greenerd Press & Machine Co.: 603/889-4101; www.greenerd.com.
Double-sided Deburring of Sheet Metal up to .2" Thick
Rolei® BE5 Deburring Machine
• Simple, one-step operation
• 40, 60, 80 and 120 grit flap wheels
• 220 V or 440 V, 3-phase
Sheet with burr after cutting
MultiMax is Ideal for All Workshop Grinding and Polishing Jobs
Multi-purpose bench grinder for steel, stainless steel and other metals – One machine uses all types of grinding discs and polishing wheel abrasives
Surface Finishing Solutions
1-800-700-5919 • www.csunitec.com
Metalforming Problems?
Get the facts.
Questions about productivity, safety, trends, technology?
Visit today for stamping and forming news, education,
MetalformingFacts.com
metal
facts
Join the conversation!
Deburring on
both sides of the sheet edges
f rming
© 2011 The Lubrizol Corporation, All rights reserved
