Page 32 - MetalForming June 2011
P. 32
Finishing Abrasives
aluminum oxide, grain utilization is only 20 to 25 percent. That jumps to 85 to 90 percent for ceramic alumina. While this performance gain pays off when grinding and finishing mild and carbon steels, fabricators will really notice the gain in productivity—fewer wheel changes and reduced labor costs—when working on hard materi- als such as stainless steels.”
For shops working with softer mate-
rials such as aluminum alloys, abra- sive-product manufacturers have you covered as well. The key here is to use a finishing product that resists loading, or won’t become “gummed up” with the workpiece material.
“What we’re recommending for alu- minum grinding and finishing,” says Long, “are products preloaded with a wax-impregnated coating (Norton Abrasives brought such a product to
market late in 2010). The coating fills the gaps between the abrasive grains so that the workpiece material can’t. Shops working with aluminum would be wise to use fiber discs rather than grinding wheels, with this wax-impreg- nated coating.”
Once you’ve selected the right abra- sive for the job, what about the prod- uct—wheel or disc? Here, Long recom- mends first and foremost that fabricators use the right tool for the job. Cutoff wheels, he says, are designed for use on their periphery, reinforced with vertical strength for edge pres- sure. Don’t try to grind with one. Like- wise, grinding wheels, with few excep- tions, are reinforced to handle face pressure—don’t try to perform cutoff operations with them. Long does note that manufacturers do offer combina- tion wheels that can cut and grind, but there’s a tradeoff in performance. “The best cutoff wheels on the market today,” he says, “are ultra-thin, 0.040 in., and can’t be used on their face. Kerf is minimal and speed optimum—they’re ideal for cutoff. A combination wheel is thicker, 1⁄8 in. or so. It can grind, but for cutoff the kerf is wider and cutting speed is slower than when using a cut- off wheel. Most users select the ultra- thin wheels for cutoff and a 1⁄4-in.- thick wheel for grinding and finishing.”
Grinding wheels offer the most aggressive action, for pure metal removal. Select a flap disc for aggressive metal removal and for applications where the ability to grind and finish at the same time is beneficial. “With flap discs,” says Long, “the operator can be steep on the edge of the wheel and remove metal much more quickly than with a grinding wheel. He can then reduce the angle of attack and make nice, wide swaths to impart a smooth surface.”
Also, flap discs, due to their buildup of overlapping abrasive-impregnated flaps, provide a cushioning effect in use. “They’re not as hard-acting as a grinding wheel,” adds Long, “avoiding vibration and optimizing operator comfort.” MF
Swing Clamps
Sliding Clamps
Guaranteed! Guaranteed!
Success Success
Hollow
Piston Cylinders
Traveling Clamps
Wedge Clamps
Swing Sink Clamps
Ledge Clamps
Pumps
Control Panels
Die Lifters
Hilma knows your die change system needs to be tailored to your individual press. That’s why, if you work with us, you’ll get the best system, and top quality results. We stand behind our products, and provide you with the excellent service you need to remain competitive in today’s manufacturing environment.
Find out the advantages of the HILMA quality guarantee when you work with us!
16345 Westwoods Business Park Dr. Ellisville, MO 63021
(636) 386-8022 • Fax (636) 386-8034 For Tech. Support Call (800) 827-2526 Email engr@clrh.com
30
MetalForming/June 2011
Visit clrh.com
SEND FOR A FREE CD OR CATALOG
