Page 36 - MetalForming June 2011
P. 36
Welding of Thin Materials
The screens in this gas lens help distribute shielding gas evenly around the tungsten electrode and the weld puddle.
round weld puddle that concentrates the heat.
As with all welding, the key to obtaining good, consistent weld quality is finding a comfortable position. While most welders will determine the optimum technique that affords the best torch control, they should position their bodies to allow them to clearly see the weld joint and the tip of the tung- sten electrode. They should keep the tip approximately 1⁄8 in. from the base material. This helps maintain a consistent arc length and prevents arc wandering, which could increase heat input to the workpiece. A consistent 1⁄8-in. gap from electrode to workpiece also helps maintain good shielding-gas cover- age and allows visibility of the weld puddle, to help the
welder control travel speed.
7]How does travel speed affect quality when welding thin materials?
A steady travel speed is critical when welding thin mate- rials. Weld too slowly and heat can build up in the base material, or the weld bead can grow too wide. Push the torch forward, as described above, so that the weld puddle remains slightly ahead of the torch and remains visible. The welder should move the torch, and add filler metal when required, at a pace that allows him to create welds whose width is approximately equal to the workpiece thickness.
8]Can a gas lens installed on a GTAW torch help when welding thin materials?
Compared to a torch equipped with a standard collet body, a welding torch outfitted with a gas lens will provide better shielding-gas coverage and more evenly distribute the gas around the tungsten and weld puddle, without the need to increase gas-flow rate.
Gas lenses typically are of brass or copper and contain layered-mesh stainless-steel screens. Improved shielding-gas
Brehm “Shimmy” Trim Dies and Tube End Trimming Dies
New,
Retool, Rebuild, Remanufacture
The “Brehm” Shimmy Die Trim Process can trim and/or notch virtually any size or shape drawn shell, tubular part, roll formed shape, or hydroformed part, leaving a burr free, precision edge. With 94 years experience and a record that includes thousands of parts between sharpening, you can trust “Brehm” Shimmy dies to give you a high quality trimmed part running in your press or in a self-contained unit.
Contact us with your applications and let us see if shimmy trimming can simplify your process.
Call us today 937-253-6194
See this technology in action at www.vulcancut.com
P.O. Box 1305 . Dayton, Ohio 45401-1305 . Fax 937-253-1062 E-mail: info@vulcancut.com
34 MetalForming/June 2011
