Page 39 - MetalForming June 2011
        P. 39
      to 1200 HV0.1) and wear resistance. Below this layer, the process forms a dif- fusion layer with fine dispersed-nitro- gen elements, says Oerlikon Balzers, resulting in high hardness to support the functional layer.
The treated tools, say BMW officials, exhibit a high resistance to abrasive wear and excellent sliding properties. Oerlikon Balzers: 205/884-1210; www.oerlikon.com/balzers
Real-Time Machining Monitoring and Data Management
Makino, Mason, OH, introduces its MPmax (Machine Productivity Maximizer) real process-monitoring and data-man- agement software, which allows a com- pany to connect multiple machines on a single network to a centralized comput- er. “With MPmax, manufacturers can detect and react to bottlenecks on the fly,” says Makino’s Jim Brown, control software development manager. “Its remote mon- itoring capabilities allow manufacturers to stay up to date with machining process- es even while they’re away from the shop floor.”
Data-management capabilities include status monitoring, machine utilization, alarms, probe data analysis, spindle and axis movement, machine power and tool management work scheduling. The ability to collect probe data and calculate the Cpk process capability index allows manufacturers to track performance and ensure qual- ity. Spindle- and axis-monitoring tech- nologies record and display axis forces, loads and speeds, data that can be used to fine-tune processes for faster cutting speeds and greater depths of cut.
Makino: 800/552-3288;
www.makino.com
Tooling Company Formed to Support OMCG Slide Machines
Users of OMCG slide machines have a new source for tooling—Precision Metal Form Inc., Bensenville, IL. The company will design (in 3D), build and test wire and strip tooling for wire sizes from 2to10mm.
Precision Metal Form: 630/561-9512; www.pmfwire.com
Hydraulic Systems Support In-Die Secondary Ops
Dadco, Plymouth, MI, introduces Power Cam and Power Pump hydraulic systems, ideal for in-die secondary operations such as punching, piercing, forming or flanging. Available in two force models, 15 and 40 kN, each system com- prises a guided hydraulic Power Cam, a nitrogen-over-oil Power Pump and a hose assembly— each sold separately. Power Cam units, constructed of long-wearing close-fitting components, incorporate small Dadco nitrogen gas springs for reliable return/ stripping force. Zero-leak- age hose-assembly quick dis-
connects are optional to ease installation.
Request a new 16-pg. color catalog for a thorough product description, operational
overview and application examples.
Dadco: 800/323-2687; www.dadco.net www.metalformingmagazine.com
MetalForming/June 2011 37
Tooling Update
