Page 26 - MetalForming July 2011
P. 26
Tooling Update
Tooling Technology
Stamper Develops Cure for Die Roll
When a recent customer request-for-quote (RFQ) specified minimum die roll on pierced holes, engineers at metal- stamping company EBway Corp., Fort Lauderdale, FL, went to work developing a special stamping die to sat- isfy the request. The RFQ addressed a 0.409-in.-thick automotive part (left) and hex-head bolts used to fas- ten the part to a mating surface. Any out-of-tolerance die roll (or curved contouring on the side of the part oppo- site to the burr side) on the part’s pierced holes could cause the bolt heads to improperly seat as they were tightened. This could result in
a misaligned assembly.
EBway designed a special die to minimize die roll and satisfy the customer spec.
The technology used, which avoids any secondary machining or grinding by the cus- tomer, can be used on materials 0.060 to 0.50 in. thick.
EBway Corp.: 954/971-4911; www.ebway.com
Gerstenslager Forms JV with Tooling Company
The Gerstenslager Co., a supplier of automotive stampings and assemblies with facilities in Wooster and Clyde, OH, announced plans to form a 50-50 joint venture with International Tooling Solutions, LLC (ITS), a designer and builder of tooling. The JV, named ArtiFlex Manufacturing, LLC, will provide engi- neering, tooling, stamping and assem- bly services.
ITS operates three facilities—two in Grand Rapids, MI, and one in Frankfort, KY, and specializes in low-cost production of ultra-low volume dies and assembly; Gerstenslager, a subsidiary of Wor- thington Industries, Columbus, OH, spe- cializes in blanking, stamping, assembly, e-coating and packaging.
ArtiFlex Manufacturing:
www.artiflexmfg.com
SOLUTIONS from The Best in Value
Resolver Based Press Controls
with built-in die monitoring,
8 PLS & networking (optional)
The Most Effective
Press Brake Guarding System
Merlin 3000 programmable profiler The Most Reliable
Ergonomic Palm Buttons
SofTouch2
2300 Victoria Avenue, Lachine (Quebec) Canada H8S 1Z8 Call us toll free 1 800 867 5787 or 1 866 ISB LITE www.isblite.com
24 MetalForming/July 2011
