Page 35 - MetalForming July 2011
P. 35
transporter magnets, which require no electricity, offer a slim profile and instan- taneous pickup and release—use them to lift parts in and out of totes and bins and for other challenging applications. Industrial Magnetics: 888/582-0823; www.magnetics.com
Lubrication System Designed for Mobility
A new mobile lubrication system from IFH Group, Rock Falls, IL, provides for stor- age and dispensing of lubricants, cutting oils, bearing oils, hydraulic fluids, trans- mission fluids and engine oils for plants requiring lubrication maintenance at multiple locations over a large area. The equipment mounts on a pallet for forklift handling and go-anywhere mobil- ity. Included are two 50-gal. and two 25- gal. steel containers with PVC sight gauges. Air-operated piston pumps on top of each container provide a 5:1 pumping ratio, while filters on the side of each con-
tainer remove any dirt or small particu- lates. A ball-valve manifold attached to the compressor allows users to turn on one, two or all four pumps at any given
time. An on-board gas-operated air com- pressor enables quick and easy startup. At the dispensing end, the unit provides retractable hose reels with metered dis- pensing control handles to indicate how much fluid has been dispensed. A large steel tool box underneath the reels allows for convenient storage of tools, grease,
rags, etc.
IFH Group: 815/626-1018;
www.ifhgroup.com
MetalForming/July 2011 33
New Products
