Page 24 - MetalForming October 2011
        P. 24
      Metalforming Problems?
Get the facts.
Questions about productivity, safety, trends, technology?
Visit today for stamping and forming news, education,
MetalformingFacts.com
Three-in-One Arc-Welding System
Thermal Arc, St. Louis, MO, has launched the first in a series of multi- process, fully integrated portable weld- ing machines designed to take on many gas-metal-, shielded-metal- and gas-tung-
sten-arc welding applications. Its intro- ductory Thermal Arc Fabricator 181i sys- tem is a portable powerhouse that delivers 180 A of welding output power.
Weighing less than 33 lb., the compact machine optimizes portability. It’s ideally suited for light fabrication, maintenance and repair welding and educational train- ing. Included is a detailed weld setup guide for optimum welding performance over a range of materials and shielding gases; digital meters with preview; infi- nitely variable voltage control; metal feed plate with quick-change drive rolls; and a receptacle for connecting remote- control devices or a spool gun.
Thermal Arc: 636/728-3000;
www.thermalarc.com
Tray-Style Sheet-
Hydroforming
Presses
Pryer Technology Group, Tulsa, OK, manufacturer of Triform sheet-hydro- forming presses, introduces two new tray-style presses designed for aircraft- parts production.
Triform presses use high-pressure
metal
facts
Join the conversation!
Looking for
Greater Output in Steel Pole Production?
For faster, more efficient pole fabrication, one source can help you reach new heights in productivity – Pacific Press. Our fully automated “total systems” approach improves your production speed and efficiency as well as the quality of your finished products.
See for yourself how our equipment can bring greater productivity and performance to your steel pole production.
Contact us to learn more:
Toll Free: 1-800-851-3586
Tel: 618-262-8666
Fax: 618-262-7000
Email: info@pacific-press.com www.pacific-press.com
Made in the USA
22 MetalForming/October 2011
© 2011 The Lubrizol Corporation, All rights reserved
f rming
