Page 85 - MetalForming October 2011
        P. 85
      Tooling Tech
G&S recently overcame these hur- dles with a takeover tool used to pro- duce five different styles of muffin pans. Among the problems experienced with this die: material feed. A mechanical feed working off of press-ram motion made feed adjustment difficult, and proved unreliable for achieving accu- rate feed lengths. Says G&S Metal automation engineer Steve Kerg:
“We improved feed accuracy by replacing the mechanical feed with an air feed and installing hall-effect sen- sors on the pistons. We also redesigned the top of the die to reduce changeover time to 20 min., and replaced all of the coil springs with nitrogen.” Previously, changeovers could take as long as a full shift. With movable rails in the die, changeovers for five parts with different widths and material thickness can be performed with little effort.
“The presence of the feed bars also is monitored,” adds Kerg, “so they can’t be smashed in the press. In the past, we might smash as many as one part per 20 due to a misfeed. We haven’t smashed a part in more than 40 shifts.”
With feed problems solved, Kerg then tackled another issue: in-die assembly of the 12 muffin cups into the frame. Some of the cups would shift during transfer, or frames them- selves could be transferred incorrectly. As did KLS Controls, G&S found its solution by installing a vision camera, which detects the presence and orien- tation of the frame. Flags on the upstroke and downstroke of the ram trigger the camera. If the camera fails to detect the part and its proper orienta- tion, the press stops and the operator clears the error on the PLC to stroke the press. If any part sticks to the upper die section, an optical part-out sensor stops the press at the top of the stroke. A custom-programmed PLC is used for sensor logic and for signaling emer- gency stops or top-stops.
Bottom line: An inherited tool that previously ran under less-than-ideal conditions now continuously produces good parts without risk of damage to the die. MF
Slip-on Abrasives Save Time & Money
Shadow-free
satin finish –
up to a mirror polish
MetalForming/October 2011 83
BE 5
Double-sided Deburring of Sheet Metal up to .2" Thick
PIPE-MAX Pipe Belt Sander
• Polish stainless and all metals
• For sanding handrails and pipes up to 12”
• Grinds weld
seams on flat surfaces
Simple, one-step operation
40, 60, 80 and 100 grit flap wheels
220 V or 440 V, 3-phase
Surface Finishing Solutions
LIVE DEMOS at FABTECH Booth 5838
1-800-700-5919 • www.csunitec.com
First Annual
Women in
Manufacturing Symposium
Sharing Worldclass Management Techniques and Best Practices
October 25-26, 2011 | Cleveland, OH
This event will provide women in the manufacturing industry a forum and venue for sharing leadership techniques, resulting in strong networking and support opportunities for attendees.
For more information go to: www.womeninmanufacturing.org
