Page 13 - MetalForming December 2011
P. 13
Restructuring at Rolled Metal Products
Metal service center Rolled Metal Products (RMP) announced plans to merge its business units in Torrington, CT, and Bensalem, PA. Machinery and inven- tory from the Torrington facility will be relo- cated to the Bensalem site, renamed Rolled Metal Products—Northeast. Appointed as managers of the facility: Ed Schulz, general manager; Stephen Krause, regional sales and purchasing manager; and Richard Kubitsky, opera- tions manager. Ron Williams remains president of RMP, which also operates a plant in Alsip, IL.
Rolled Metal Products:
www.rolledmetalproducts.com
Brochure Introduces an Alternative to Acid-Pickled Strip
A brochure from Red Bud Industries introduces the Eco Picked Surface (EPS) process as an environmentally friendly direct replacement for acid pickling. Comparatively, EPS lines consume less floor space and are less expensive to operate. The process uses a slurry mixture of water and steel grit propelled onto the strip in a
uniform stream to remove surface scale.
The EPS process also can reduce common mill imperfections such as roll marks, pitting and silicon streaks. And, according to Red Bud, EPS-processed steel resists rusting longer than does pickled steel, and it can be shipped dry
to customers, eliminating the need to oil the material.
The brochure goes on to explain the benefits of the EPS process when weld- ing, stamping and rollforming.
Red Bud Industries: 618/282-3801; www.redbudindustries.com, www.epsprocess.com
Materials & Coatings
connect everywhere
Network your factories and offices with SmartPAC 2 and LETS (Line Efficiency Tracking Software)
Take advantage of
SmartPAC 2’s built-in Ethernet connectivity to communicate over your network.
Send and receive text messages, display setup sheets stored on a central server, back up your tools to a remote location, and view pressroom status over the network and internet. When you connect your equipment to LETS, you can collect production data, feed critical parameters reports automatically, view machine status in real time, and schedule a prioritized job queue for each machine.
To learn more about Wintriss Controls, please call 1-800-586-8324 or visit www.wintriss.com. ®2011 Wintriss Controls. All rights reserved.
MetalForming/December 2011 11
