Page 50 - MetalForming December 2011
P. 50
Ask the Expert
MetalForming magazine presents: Ask the Expert. These brief infor- mational tidbits allow readers to learn from those who have the answers. If you’d like to see your technical question addressed here, please e-mail the editor: bkuvin@pma.org.
If your company provides technology-based solutions to the met- alforming industry, please contact Andrew Flando at aflando@pma.org to learn more about this program.
Straightening HSLA Steel
Matt Watson, national sales manager, Formtek Maine
Q:Every time we attempt to straighten high- strength low-alloy (HSLA) steel with our
existing press-feed equipment, originally purchased for mild-steel applications, we struggle to achieve flat parts. What are our options for dealing with HSLA material?
A: To achieve flat parts, the material must be worked beyond its yield point to remove internal stresses. Typically, straighteners designed for mild steel use large-diameter rolls with large center dis-
tances between the rolls. To effectively straighten HSLA material, what’s required are smaller-diameter backed-up rolls with close cen- ter distances. www.cwpcoil.com
In-Die Sensing
Jim Finnerty, product manager, Wintriss Controls
Q:We’re running a progressive die blanking 0.008-in. stainless steel, and are getting
pulled slugs that get squashed into the part by the stripper. We’re having difficulty detecting the problem with our tonnage monitor. Is there a better way to do it?
A:The increase in tonnage caused by a pulled slug under the stripper is too small to be reliably detected. Use analog induc-
tive proximity sensors to measure the height of the stripper plate at bottom dead center. When a slug is pulled, the stripper will be too high; the sensors will detect this and stop the press, even if the strip- per height difference is as small as 0.0005 in. www.wintriss.com
Ad Index
Advertiser Pg#
Can-EngFurnaces .....................................41 Chemcoaters ..........................................36 ChristyMetals .........................................36 FutureProducts ........................................14 HilmaDiv.ofCarrLaneRoemheld .......................10 ISB . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .6 LinearTransferAutomationInc. ..........................5 Link Systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 MFGMeeting,The ...................................43 MurataMachinery ...................................10 P/A ................................................BC PHDInc. ............................................8 PMA
Membership .......................................IBC
MetalFormingmagazineERPExperience ...............34 PhygenCoatings,Inc..................................14 PlexSystems,Inc. .....................................3 Stamtec .............................................9 Union Tool Corp. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .7 Unist, Inc. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .8 WayneTrailTechnologies,Inc. .........................IFC Wintriss Controls Group LLC . . . . . . . . . . . . . . . . . . . . . . . . . . .11
Telephone#
905/356-1327 877/411-2905 800/356-7923 800/237-5754 636/386-8022 800/867-5787 705/735-0000 615/833-4168
800/243-8306 800/624-8511
216/901-8800 888/749-4361 855/534-8012 931/393-5050 574/267-3211 313/918-1246 937/295-2120 800/586-8324
Web Address
www.can-eng.com www.chemcoaters.com www.christymetals.com www.future-products.com www.clrh.com www.isblite.com www.lineartransfer.com www.linkelectric.com www.mfgmeeting.com www.muratec-usa.com www.pa.com www.phdinc.com/mf1211
www.pma.org www.metalformingmagazine.com www.phygen.com
www.plex.com www.stamtec.com www.uniontoolcorp.com www.difficultdraws.com www.waynetrail.com www.wintriss.com
48 MetalForming/December 2011
