Page 30 - MetalForming March 2012
P. 30
TOOLROOM TECHNOLOGY
hand we can approach management and make a strong case for capital expenditures, targeted at addressing specific capacity needs.”
A Technology Tune-up
Over the last 3 yr., Oberg has invest- ed more than $10 million in new machining equipment. It also has con- tinued to customize special machining platforms to perform its proprietary Molecular Decomposition Process (MDP). It uses the process where sur- face quality of die components is absolutely critical—typically found in Series I and II dies, but occasionally specified in Series III dies as well.
“During MDP, we establish a cath- ode-anode relationship between the abrasive wheel and the workpiece,” Rugaber explains. “As a result, we can remove stock as much as 80 per- cent faster than with conventional grinding.”
Using MDP, which Oberg now has installed on more than 10 grinding
Oberg has the same number of wire-EDM operators it had 5 yr. ago, but is sending 30 to 40 percent more product out the door. This is due, in part, to automation that enables unattended machining.
“SMART” HYDRAULIC PRESSES
50-ton deep-draw forming press with infinitely adjustable closed loop multi- axis position and velocity control, touch screen HMI with recipe stor- age, proportional pressure control of ram, and joystick for manual control.
To meet the growing need for highly specialized equipment, Multipress has rapidly expanded its custom engi- neering capability. Our high-tech, spe- cial-purpose presses, designed to meet your most demanding require- ments, are the most accurate and productive machines we’ve ever built.
Call Gene at 614-228-0185, ext. 231 for details and an eye-opening quote.
www.multipress.com
28 MetalForming/March 2012
