Page 51 - MetalForming March 2012
P. 51
Tooling by Design
We ship everywhere.
• Aluminum • Brass Alloys • Copper • Beryllium Copper christymetals.com • Nickel Alloys • Phosphor Bronze • Cupro Nickels
• Nickel Silvers • Stainless Steel • Zinc Strip Alloys 800.356.7923
and wear resistance of the treated steel. Cryogenictreatmentsoccurattemperaturesbelow-238F.
Since cold and cryogenic treatments both occur at sub-zero temperatures, it would not be appropriate to distinguish one or the other as a “sub-zero” process, because both are sub-zero treatments.
With hardened tool steels, exposure to cryogenic tem- peratures eliminates most of the retained austenite in favor of the more wear-resistant martensite. More importantly, it also initiates the precipitation of wear-resistant carbides from the martensite phase, enhancing the steel’s overall durability and toughness.
For machine shops and metalformers, cryogenic treat- ments also can increase the life of drills, taps, mills, cutters, saw blades and broaches by 200 to 400 percent, according to one recent study. And in another study, an automaker report- ed resistance-welding electrodes running six times longer after cryogenic treatment.
After cryogenic treatments, tool steels will require at least two tempering cycles in a tempering oven. These steps can be quite time consuming—as long as 20 hr.—but they are a necessity, not an option. The entire process can take 3 to 4 days, so plan accordingly. MF
Celebrating
Yearsof 1942-2012 Excellence
PMA Celebrates 70Years of
Excellence
The Precision Metalforming Association (PMA) plays a vital role in the metalforming industry. To honor PMA’s 70 years of serving the metalforming industry, MetalForming magazine, the official publication of PMA, will produce a special section in its July 2012 issue.
To join in the celebration, look for more information in upcoming issues, or contact Andrew Flando, aflando@pma.org.
www.pma.org www.metalformingmagazine.com
Quick Die Change Success
Hydraulic Die Change:
• Swing Clamps
• Sliding and Swing Sink Clamps • Wedge and Traveling Clamps
• Hollow Piston Cylinders
• Pumps, Control Panels
• Die Lifters
HYDRAULIC Die Clamping
Hilma has been safely clamping dies for more than 50 years. We know your die change system needs to be tailored to your individual press. We stand behind our products, and provide you with the excellent service you need to remain competitive in today’s manufacturing environment.
SEND FOR A FREE CD OR CATALOG
clrh.com/hilma
Now Introducing MAGNETIC Quick Die Change
• Clampsexisting dies without retooling
• Evenlydistributed clamping force reduces tool wear
• Availablefora range of sizes.
16345 Westwoods Business Park Dr. Ellisville, MO 63021
(636) 386-8022 • Fax (636) 386-8034 For Technical Support Call
(800) 827-2526 • email engr@clrh.com
MetalForming/March 2012 49
