Page 54 - MetalForming May 2012
P. 54
Tooling Update
Tooling Technology
Abrasive Nylon Disc Brushes—A Single Tool Removes Burrs, Improves Surface Finish
for general-purpose deburring and surface- finishing applications; and Turbine style for medium and heavy deburring. The Dot style is an economical choice for light deburring when short cycle times are
important. Dot-style brushes provide opti- mum flexibility and allow entry into small holes and spaces with ease. The Turbine-style brush has a high-den- sity fill, ideal for short cycle times and longer tool life.
Both styles of brushes are designed for use with the new Flow Through Coolant
holder, a professional-grade tool holder that allows coolant to flow from the brush center instead of supplying lubri- cant only from the outside. Center coolant flow results in better lubricant dis-
Brush Research Manufacturing, Los Angeles, CA, introduces a unique new line of Nampower abrasive nylon brushes that contain a combination of ceramic and silicon-carbide filaments to—in one oper- ation—deliver optimum burr-removal rates and ideal surface finish. The abra- sive filaments on the Nampower tools work like flexible files, conforming to part contours and wiping and filing across part edges and surfaces. Because of the linear construction, sharp new grains con- stantly come in contact with the work sur- face and wear off, exposing fresh cutting particles. This provides consistent debur- ring action throughout the length of the bristles.
The abrasive brushes are easily inte- grated into automated machinery—CNC machining centers, transfer lines and robotic cells used for machine inline deburring, edge radiusing and surface fin-
ishing. Typical applications include remov- ing burrs and blending tool marks in punched and fineblanked components
and stamped parts; deburring face- milled surfaces; improving surface finish; edge radiusing; and blending.
Nampower Tools are available in two different fill configurations: Dot style
Solutions in scrap management.
At OmniSource, we take great pride in supporting our scrap-generating customers with customized solutions— solutions developed over decades of using the most-advanced technologies and reporting tools available. We provide world-class service to a varied customer base throughout North America, from the smallest scrap generators to some of the largest manufacturers. Our comprehensive reporting, strict adherence to environmental standards, and proven financial strength give you peace of mind that you’re partnering with a leader in the recycling industry. Call us—we’ll find a solution that’s right for you.
Any Metal. Anywhere. Anytime.
www.omnisource.com
For more information contact
Steve Bardon
sbardon@omnisource.com (260) 423-3950 office (419) 392-2360 cell
7575 West Jefferson Boulevard Fort Wayne, Indiana (800) OMNI-789
52 MetalForming/May 2012 www.metalformingmagazine.com
