Page 18 - MetalForming June 2012
P. 18
Materials & Coatings
Access SSAB Steel Info via Free Mobile App
High-strength-steel
provider SSAB has devel-
oped a free mobile app for Android and iPhone users to pro- vide access to information about its steel alloys, instruc- tions for steel processing, product datasheets and more. Download the app from the Apple Store or Google Play. SSAB: www.ssab.com
Nano-Ceramic Grease Ideal for Forklifts and Lift Trucks
Dayton Progress, Dayton, OH, has introduced DayLube high-performance grease, recommended for the protection of forklift and lift-truck masts and runners conveyor bearings, bushings cables, cams, chains, gears, lifters, machine parts, robotics, slides, wear plates and the like. The grease features nanoceramic particles that act as sub-microscopic ball bearings to provide continu- ous lubrication to steel surfaces. With a lower coefficient of friction at all temperatures than traditional PTFE greases, chemically inert DayLube also is environmentally friendly.
The lube maintains its viscosity across a temperature range of -40 to 800 F, and boasts extraordinary adhesion to extend production by as much as 10-times com- pared to other greases. It has high load-bearing properties, a low dielectric constant, does not contain metal or sil- icone and resists steam, acids and most chemical products.
DayLube comes in 16-oz. tubes and in cases of 12 each.
Dayton Progress: 937/859-5111; www.daytonprogress.com
Tailor Welded Coils: Unlimited Possibilities
Tailored products for coil fed operations such as; progressive die, roll forming and coil fed transfer presses
Slit Product Benefits:
Tailor Welded Coil
The new light weight steel
Customer
Progressive die
Roll forming
Weld
Coil
Wide coils
Coil fed
transfer presses
TWB Company
16 MetalForming/June 2012
