Page 59 - MetalForming July 2012
P. 59
    Tooling Update
Grinder Takes Tool Sharpening to the Next Level
Foremost Machinery, Northbrook, IL, introduces Hunton vertical grinders, which provide an economical way to keep turret-press tooling sharp and optimize sur-
face finish. The tabletop grinder, with a hand wheel grad- uated in 0.001-in. increments, is designed to help fabricators reduce costly tool inventory and toolroom exchanges. It’s reportedly more precise than surface grinders used for tool sharpening, and will produce comparable results to automat- ed tool grinders that cost four to five times
as much.
The grinder uses a magnetic chuck for die
buttons and a three-jaw chuck for punches. Hunton offers six models to choose from, including the BG790 that includes a coolant tank, splash guard and pump for wet grinding. Options include quick-change adapters, used with the shear-grind chuck to allow sharpening of tooling with mini-
mal disassembly.
Foremost Machinery Corp.: 847/272-7800; www.foremostmachinery.com
Two-Finger Adaptive Gripper Overcomes High-Mix Automation Challenges
Robotiq, St-Nicolasis, Montreal, Canada, has introduced an innovative two-finger grip- per to replace the use of robotic tool changers that provide only limit- ed and expensive solutions when required to handle a variety of parts. Applications include high-mix processes such as light assembly, sorting and kitting, packaging, machine tending, bin picking and parts transfer. Says one recent customer
of the gripper:
“A recent job for our
robotic nut-welding cell (resistance welding) required us to load more than 30 differ-
ent parts,” says Steve Spanjers, director of engineering at automotive stamper Marwood Metal, Tillsonburg, Ontario. “Hav-
ing to design several custom grippers was a big con-
cern. We found the two-finger adaptive gripper to be
a flexible solution able to grip all of our parts, which
reduced tooling costs and eliminated time consuming changeovers.”
Fully programmable, the robotic gripper provides:
• Three gripping modes–parallel, encompassing and inside grip–for handling dif- ferent part geometries including flat, square, cylindrical and irregular.
• High payload-to-weight ratio coupled with long stroke, to enable handling of a variety of sizes in a compact form factor.
• Precise speed and force controls, for handling parts of different rigidities—from brittle to deformable to stiff.
• Accurate finger control, to minimize cycle times through partial open/closing.
Robotiq: 888/762-6847; www.robotiq.com www.metalformingmagazine.com
   57   58   59   60   61
