Page 16 - MetalForming August 2012
P. 16
Waterjet Cutting Keeps the Work Flowing
on the Model 55100.
“While aluminum cuts fairly straight
and often does not require compensa- tion,” he says, “steel can taper quite a bit.” Taper occurs because the energy of the waterjet is greater at the top of the cut than at the bottom, resulting in a wider kerf at the top. In some cases, fabricators can experience reverse taper. Here the waterjet removes more material from the bottom of the cut than from the top; the phenomenon can occur during very slow cuts or when working with very soft materials.
The Tilt-A-Jet cutting head positions the nozzle at an angle determined by the Omax Intelli-Max software—based on material type and thickness, and cutting speed—to compensate for the predicted taper. This moves the tapered edge to the scrap rather than the work- piece. The head offers programmable tilt to ± 9 deg., as well as 6 in. of vertical travel.
“The parts come off perfectly square with taper-free edges,” says Stegh,
Stegh pointed out this plate skeleton to highlight the edge straightness and quality achieved with waterjet cutting. Shown is 2-in.- thick type 4140 mild steel. “This is wire-EDM-like quality,” he says, “with top-to-bottom straightness within 0.020 in.”
“without having to reduce cutting speed—the alternative method to reduce taper. We’re achieving taper as little as 0.003 in. top to bottom on 1-in. steel plate. That’s unheard of, on par with wire-EDM.”
In addition to software support for taper compensation, Stegh also appre- ciates the software’s ability to control cutting-stream pressure to allow pierc- ing of brittle materials. “That feature has allowed us to pierce and cut ceram- ic tile and glass,” Stegh adds.
The ability to quickly produce straight-walled precision cuts allows Stegh to process some work that might otherwise require CNC machining—a slower and more costly option. “And, we can waterjet-cut very small holes in thick plate that we’d otherwise have to machine,” he says. “For example, we just processed a part from 3⁄4-in. mild steel that required waterjet cutting of 0.312-in.-dia. holes. Can’t do that on a laser, and it’s much more cost effective than CNC machining.” MF
“SMART” HYDRAULIC PRESSES
20-ton assembly press with enclosed C-frame design for near-zero deflection, precision electronic control of ram force, position and speed, convenience port for ethernet commands to PLC, customized hydraulic features, and touch screen HMI with multiple recipe storage.
Custom engineered to integrate with today’s shop floor
technology.
Our high-tech, special-pur- pose presses, designed to meet your most demanding requirements, are the most accurate and productive machines we’ve ever built.
Call Gene at 614-228-0185, ext. 231 for details and an eye-opening quote.
www.multipress.com
14 MetalForming/August 2012
