Page 12 - MetalForming September 2012
P. 12
axially sliding locking bolt and a mechan- ical clamping gearbox. This design allows for high clamping forces and dynamic stiff- ness while keeping weight at a minimum. For tool changing, a vertical stroke is required. Model PKV is available in two versions: the fully automated pneumat- ically driven PKV-P and the manually operated PKV-M.
The Model PKH horizontal coupling, also available as a fully automated pneumatically driven model and as a manually operated model, also consists of active and passive tempered-steel parts, with a portion of the unit con- structed of aluminum. In the active part, clamping force is generated by the use of a vertically sliding clamping pin in com-
bination with a coupling pin in the pas- sive part.
The couplings feature patented force amplification via a wedge clamping design, and can compensate for a gap as large as 5 mm between the active and passive parts of the coupling.
GAM Enterprises: 847/649-2500; www.gamweb.com
Press-Type Spot Welder Tackles Resistance Welding of Aluminum
After struggling for years with incon- sistent welds produced by an under- sized rocker-arm spot welder, this 30- employee precision sheetmetal fabricator now is actively seeking work that involves the resistance-welding process.
“Our shop gained a whole new depart- ment due to the purchase of two heavy- duty spot welders,” says Greg Johnson, president of LJ Fabricators, Rockford, IL, who manages the family-owned compa-
ny with his brother Chris, vice president of operations.
“We don’t usually purchase equipment until there’s a need,” continues Greg, “and several years ago a customer pre- sented us with the opportunity to fabri- cate a large quantity of parts made of 0.050-in. aluminum. Our traditional method of gas-tungsten-arc welding of those parts would have been too slow and cost- ly, so we decided to spot weld them.”
When it became obvious to the John- son brothers that LJ’s light-duty 30-KVA rocker-arm spot welder would not handle aluminum, they looked to T. J. Snow Co., Chattanooga, TN, to provide a reman- ufactured press-type spot welder. T.J. Snow had converted the machine from its original AC transformer to a state-of- the-art mid-frequency direct-current (MFDC) transformer and control.
The high secondary-amperage out-
Solutions in scrap management.
At OmniSource, we take great pride in supporting our scrap-generating customers with customized solutions— solutions developed over decades of using the most-advanced technologies and reporting tools available. We provide world-class service to a varied customer base throughout North America, from the smallest scrap generators to some of the largest manufacturers. Our comprehensive reporting, strict adherence to environmental standards, and proven financial strength give you peace of mind that you’re partnering with a leader in the recycling industry. Call us—we’ll find a solution that’s right for you.
Any Metal. Anywhere. Anytime.
www.omnisource.com
For more information contact
Steve Bardon
sbardon@omnisource.com (260) 423-3950 office (419) 392-2360 cell
7575 West Jefferson Boulevard Fort Wayne, Indiana (800) OMNI-789
10 MetalForming/September 2012 www.metalformingmagazine.com
