Page 57 - MetalForming September 2012
P. 57
higher construction costs and increased tolerance accumulations.
Station-number factor Fn deter- mines a strip layout’s effectiveness in terms of the number of stations it includes. An Fn value of 100 (best pos- sible) represents a minimum number of stations—two. In contrast, an Fn of 10 represents the maximum number of stations, typically the total num- ber of punches used for cutting and bending.
Fn =100–90x N–Nmin Nmax – Nmin
N = total number of stations in the strip layout; Mmax = total number of punches (cutting and bending); and Nmin = the possible minimum number of stations, Nmin = 2
Tipping Moment
Also required is a moment-balanc- ing factor, Fb. When two or more die stations perform their task on the die strip, the forces simultaneously act on the strip at different points. If the reac- tion forces are unbalanced relative to the press centerline, ram tipping occurs. The moment-balancing factor indicates how near to center the equiv- alent reaction forces are to the axis of the press ram. Since the center of the die usually aligns under the center of the ram, this factor considers tipping- moment severity—seldom considered in strip layouts.
All stamping presses have a maxi- mum tipping moment, established by the press builder, that represents the maximum off-center loading condi- tion that the press can safely handle without suffering long-term damage. Designers use this rating to establish a maximum off-center loading parame- ter, Dmax.
To calculate the moment balancing factor:
Fb = 100 – 90 x d Dmax
When d = 0, the center of the ram and of the stamping loads are com-
pletely matched, so Fb = 100 (best con- dition). When d > Dmax, the deviation is so serious that Fb = 10 (worst condi- tion). Similar factors can be established for strip stability and strip lift. Then the designer assigns corresponding weighting factors based on their impor- tance to the strip layout.
The resulting evaluation score (Ev)
provides die and process engineers with a performance-based numerical rating to evaluate each strip layout. The evaluation score has relative mean- ing for different layouts producing the same part. It therefore can be used to find the best solution for that particu- lar part.
Or, we can continue guessing. MF
Tooling by Design
GET A PRESS
as unique as you are.
Technology that’s just right for your needs.
BECKWOOD PRESS
St. Louis, Missouri, USA
Service that ensures total satisfaction.
Quality for lifelong dependability.
For more information, visit
www.beckwoodpress.com or call 800.737.0111
Made for you. Made to Last.
MetalForming/September 2012 55
11:42 AM
