Page 32 - MetalForming October 2012
P. 32
Educational Program
with the assistance of an integrat-
ed filler-wire system.
Design for Laser Joining
Learn how the choice of laser type, component material selection, weld joint design, component part preparation and part fixturing all are critical to successful implemen- tation of the laser-welding process.
Innovation and Emerging Laser Technology: The Critical Role of the Control
Decades of domain expertise are integrated into CNC functionality, delivering a powerful platform to develop versatile systems.
Forming & Fabricating Track
Monday, November 12
8:00 a.m.–10:00 a.m.
Rollforming Fundamentals
Basic Roll Design
Learn basic rollforming-design
principles that will help make
designs more functional.
Fundamentals of Rollforming
Learn how to design and produce parts regardless of the material by understanding the typical roll- forming process and what can be rollformed.
Reducing Costs through Innovative Sheetmetal Design
This presentation will change the way a designer thinks about the entire part-design process by incorporating all the necessary operations, including laser cut- ting, punching, bending, laser and conventional welding.
Press Brake—Part Design and Forming Fundamentals for Operators, Supervisors and Engineers
Too frequently a disconnect occurs between part design and the ability to successfully form the part to the specified tolerance.
This presentation provides a basic understanding of press brakes and press-brake tooling.
10:30 a.m.–12:30 p.m.
General to Advanced Rollforming Concepts Update Your New or Existing Rollforming Lines with In-Line Punching and Cutoff Solutions
Learn how to integrate your roll- forming lines with cutoff and punching operations.
Rollform Tooling Setup and Troubleshooting
Learn the proper way to install rollform tooling, make the neces- sary adjustments and trou- bleshoot problems.
1:30 p.m.–3:30 p.m.
What’s New in Press Brakes
The Other Side of Press Brake Automation
Reverse Tonnage / Snap-Through? Mechanical Safety Lock
Shock Dampers
IC-Fluid Power, Inc.
HIGH QUALITY GERMAN PRESS PRODUCTS IN ACTION
30
MetalForming/October 2012
