Page 48 - MetalForming October 2012
P. 48
Cut-to-Length Line Capability on Display
Coe Press Equipment Booth C1323
Coe Press, Sterling Heights, MI, will feature its value-offer- ing cut-to-length (CTL) lines, developed using standard coil-han- dling and feeding equipment, with the addition of optional spe- cial features such as a Coe shear as well as a stacking solution. The
end result is a complete integrated line.
Coe CTL lines can process coil from 18 to 72 in. wide, 0.020 to 0.375- in. material thickness, and 6000 to 60,000 lb. coil weights. They’re suit- ed for a variety of materials including cold- and hot-rolled steel, galvanized
steel, stainless steels and aluminum alloys.
www.cpec.com
Fiber Laser Shares Spotlight with Hybrid Press Brake Ermak USA
Booth C3447
Ermak USA will display its relatively maintenance- free fiber-laser cutting machine that boasts state-of- the-art linear drives, providing fast, accurate and silent operation. Sharing the spotlight: the firm’s Evolution hybrid press brake, which needs only 8 gal. of oil, and also promises to require little to no maintenance.
www.ermakusa.com/usa
UNIQUELY YOURS
UNIQUELY YOURS
100 and 50 ton press cell for precision assembly of safety-critical inline ball joints. Motion con- troller and PLC govern 3-stage ram downstroke. Electronic servo control with precision feedback, together with a pressure transducer and linear transducer maintains 1% of force and .0015” tolerance on ram contact position.
Customized hydraulic presses engineered to meet YOUR needs and YOUR shop floor technology.
We work with you to design electronically- controlled special-purpose presses that consistently deliver high-quality parts and globally competitive productivity.
Call Gene at 614-228-0185, ext. 231 for details and an eye-opening quote.
sales@multipress.com www.multipress.com
See us at Fabtech, Booth C1022
46 MetalForming/October 2012
