Page 54 - MetalForming October 2012
P. 54
Servo-Actuated Spot Welder
T.J. Snow Co. Booth N2613
T.J. Snow introduces to FABTECH attendees its lineup of SlimLine pedestal-type spot, projection and seam welders. Features include instant weld force—faster than air-operated spot welders; low operating cost—no expensive, dirty compressed air; optimum weld-force repeatability; reduced tip wear and improved weld appearance with slow approach; built-in monitoring of part stackup and tip wear; detection of miss- ing weld nuts; and programmable set-down limits for projection welding.
PM, High-Speed Tool Steels
Bohler-Uddeholm Corp. Booth C1417
Type D Ball-Bearing Systems
Superior Die Set Booth C658
Superior Die Set intro- duces new ball cages that are interchangeable with standard pin and washer assemblies. Type D sys- tems are available with the original Superior Maxicage end-cap system, and also are offered with S cage springs.
www.supdie.com
See Us at FabTech Booth # C947
Bohler-Uddeholm Corp., Elgin, IL, a provider of specialty tool steels, heat- treatment and coating services to the metalforming industry, will feature its com- plete line of powder-metallurgically pro- duced tool steels and high-speed steels. Also on display: its new Thermo-Tech nitriding vacuum-heattreating capabilities.
www.bucorp.com
R
C
S
F
K
O
F
S
R
I
D
A
R
O
O
D
U
T
M
C
O
I
S
E
L
L
P
M
G
U
N
R
S
O
A
A
E
E
R
I
U
O
I
T
I
N
E
R
E
M
W
L
L
U
G
S
T
U
D
Y C
I
A
P
A
S
G
E
L
R
I
R
O
P
U
T
A T
N
I
V
R
T
A
E
S
O
L
P
A
F
B
T
T E
S
E
E
52
MetalForming/October 2012
www.tjsnow.com
Forming Systems
Hydroforming Warm Forming Hot Gas Forming Hot Stamping
Pressure Systems
Leak Testing Burst Testing Impulse Testing Hydrostatic
