Page 22 - MetalForming April 2013
P. 22
obtain precise traversing profiles. Now, this function is handled by the motion-con- trol system in conjunction with the servo pumps, which allows the valve systems in the press to be reduced by as much as 40 percent. The end result is a notable improvement in energy efficiency. The energy-saving effect is particularly appar- ent, says Barnickel, during the drawing
operation, when drawing pressure is provided by a pump equipped with a servomotor with the motor of the die cushion pump operating as a generator.
Although the Simotion controller has been optimized for motion-control appli- cations, it also can control the com- plete system. However, Lasco separates the various press tasks and uses a
separate PLC for system control. The development of servo technology for large hydraulic presses, based on the Simotion motion-control system, also is suitable for modernization and retro- fit projects.
Lasco USA: 734/241 0094; www.lascousa.com
Siemens: www.usa.siemens.com/ motioncontrol
Servo-Drive
Flying Cutoff Press
Airam Press Co. Ltd., Covington, OH, has developed a pneumatic flying cutoff press with a servo drive that provides the flexibility to perform stamping and roll-
Make Smarter use of Your Energy...
Through Storing
& Applying Pressure!
Our designs have a proven track record of more than 50 years with the most comprehensive offering of accumulators, and related accessories in the industry.
From 10 cubic inches to 200 gallons, 100 PSI to 20,000 PSI
...with Tobul, the pressure is always on!
Lator ®
61 Innovation Drive l Bamberg SC 29003 USA l tobul.com l 803.245.2400
E
E
c
conoL
20 MetalForming/April 2013
forming operations, as well as extru- sion applications. Use the press to stamp, punch, cut or pierce, as part of a stamping work cell or as the anchor of a rollforming line.
“The servo-driven flying cutoff can move in and out of the material three times faster when compared to similar- ly equipped hydraulic and mechanical presses,” says Airam sales manager Matt Barkman, “Tooling doesn’t have to travel as far, which minimizes the overall footprint.”
Airam: 800/842-4726; www.airam.com
