Page 30 - MetalForming June 2013
P. 30
Press Controls
ARaymond manufacturing manager Justin McCullah shows off the company’s new “die-protection toolbox” that houses
an array of proximity, ring and laser sen- sors. Each sensor is prescribed for certain duties on the plant’s high-speed presses,
to protect its aging set of dies that lack the room to house sensors onboard.
objectives (MBOs) for every employee, hold them accountable and reward them for success,” says McCullah. “In 2011 we asked our employees to reach the efficiency-improvement goals we established on 80 percent of our work orders. We upped that to 85 percent last year and 90 percent this year.” Employ- ees were rewarded for their efforts with a performance bonus in 2012.
Of course when it comes to press run rates, just cranking up press speed does not easily nor automatically trans- late into increased throughput. Most notably, the accompanying adjust- ments made to the coil-feed line rep- resent a critical success factor. And here’s where another unique capabili-
ty of the Wintriss SmartPac 2 comes into play—it’s called Feed Advisor.
With SmartPAC 2’s Servo Feed Inter- face (SFI) option, available for most brands of servo feeds (including the Rapid-Air feeds that ARaymond has added to its upgraded press lines), users can program, store and auto- matically download feed parameters for each tool. With a programmed feed
length, feed arc and press speed, the SmartPac determines whether or not the feeder can operate in the time avail- able. It then calculates the minimum feeder acceleration rate required.
“Feed Advisor helps our press tech- nicians and setup people by analyzing when the feed occurs relative to die closure,” says McCullah. “Without this feature, we would spend countless
The most reliable,easy-to-use Heavy-Duty Tool Changer. Ever.
A more reliable fail-safe.
A patented “springless” mechanical fail-safe is guaranteed to work, even with loss of air pressure.
A more reliable locking mechanism.
7,000 pounds of locking force guarantees that signals pass flawlessly, even with heavy accelerations and payloads.
A more flexible utility solution.
Widest choice of modules (power, fluid/air, signal, and more) with common mounting features for greater flexibility.
With patented advances in the locking mechanism and failsafe, and new flexible module mounting and integrated robot mounting patterns, we’ve created the most reliable, easy-to-use Heavy-Duty Tool Changers. Ever.
ATI’s Heavy-Duty Tool Changers have set a new standard.
www.ati-ia.com 919.772.0115
ROBOTIC END EFFECTORS
28 MetalForming/June 2013
