Page 47 - MetalForming June 2013
P. 47
they did what is known as a one-step simulation, a relatively fast directional indicator of potential forming issues. The process serves as a compass for early feasibility to a product engineer— a mere substitute for not having an experienced die engineer review the design early in the development process.
Simply, a one-step simulation math- ematically calculates strains by taking a finished part to a flat blank in one step—sort of like dropping an anvil on a stamping to see if it splits. Hardcore finite-element-analysis (FEA) profes- sionals may have an issue with this characterization, but the point is that one-step technology is not accurate enough to determine production risk of whether a die process, die architecture and blank can stamp product from HSLA or DP steel under production conditions without splits or wrinkles.
In addition to a one-step simula- tion, shops can opt for a multi-step simulation—a series of one-step sim- ulations that enables an engineer to segregate drawn features from flanged features, such as return flanges. At the die shop, you need a map—not a com- pass—to navigate your way from quote to buyoff.
Incremental forming-simulation software is as close to standing at the tryout press as you can get. This simu- lation technology digitally replicates the actual forming process. It requires form-tool surfaces and mechanics, and blank geometry. The software uses the tools and blank to calculate formabil- ity throughout the sheet thickness dur- ing each fractional increment of press stroke.
Software Platforms
Incremental forming-simulation software platforms are built around two types of users: the FEA expert and your average everyday die guy. The FEA platforms require an expert to create what is known as a mesh; mesh size helps to determine simulation accu- racy. The software still requires engi- neered form-tool geometry and a blank. Meanwhile, software platforms designed for the average die guy auto-
mate meshing tasks.
So, how do you know which plat-
form is right for you? Those that actu- ally know what the phrase “transversal shear stress” means and can use it in a sentence should typically opt for the FEA platform. Otherwise, I recommend using software that automates the meshing procedure.
The software brand choice may already be decided for you depending
upon your customer base. Some com- panies—VW and BMW, for example— govern the software brand for their incremental forming simulations.
Keep in mind that most FEA experts can successfully use any of the soft- ware brands on the market, provided that the die processing is performed in CAD by a die guy. The converse is typ- ically not true: Most die guys struggle to use the FEA-driven simulation brands
Tooling Technology
QUICK DIE CHANGE SUCCESS!
HYDRAULIC DIE CLAMPING:
Hilma has been safely clamping dies for more than 50 years. We specialize in die change systems that maximize the output of your specific press. We stand behind our products, and provide you with the excellent service you need to remain competitive in today’s manufacturing environment.
Now Introducing
MAGNETIC
QUICK DIE CHANGE:
Clamps existing dies without retooling
Evenly distributed clamping force reduces tool wear
Available for a range of sizes.
Pumps, Control Panels
Die Lifters and Roller Bars
View Stamping Products at: www.clrh.com
Ellisville, MO 63021 (636) 386-8022
MetalForming/June 2013 45
