Page 52 - MetalForming June 2013
P. 52
Classifieds
PRESS REBUILDING
EQUIPMENT FOR SALE
DIES • DESIGN/BUILD
INDUSTRIAL MACHINE REPAIR
N Field Millwright Services N Welding & Brazing
N Heavy Machining
N Press Inspections
N Clutch and Brake Retrofits
N Consultation Services
N Used Parts & Rebuilt Presses
For Sale
Phone: (812) 346-2216
Coil Handling and Press Feeding Equipment In Stock Remanufactured/Reconditioned
• Servo Roll Feeds • Coil Feed Lines • Coil Straighteners • Coil Reels
Servo Roll Feed Control Retrofits
In Stock:
Minster Coil Feed Line 20,000 Lbs. x 50"
Wide x .060"
Coe Press Coil Feed Line 20,000 Lbs. x
42" Wide x .125"
Dallas Servo Roll Feed 24" Wide x .290"
Pneumatic Feed Service
586/774-6675
www.pressfeed.com
Metal Stamping
Lubrica
tion Solutions
Since 196
4
SAFETY VALVES
LUBRICATION
MicroSpray Systems Roller Coater Systems Spray Cabinets Airless Spray Systems
Computer Controlled Systems
email:sales@lspind.com 800-577-7895
www.lspind.com
METAL PURCHASING
DIN 24342 Safety Active Poppet Sizes: 25MM; 32MM & 50MM 5000 PSI
• Standard ISO 7368 and DIN 24342 cavity and porting.
• Control areas provide fast response time.
• Can close poppet under high load pressure.
• Built-in limit switch provides position feed- back of Main Cartridge, AC or DC.
• Meets ANSI B11.2-1995 safety requirements for hydraulic power press clamp circuits.
For more details contact
Almo Manifold & Tool Company
sales@almomanifold.com or visit us online at www.almomanifold.com
• FACCIN 4 - Roll Hydraulic Plate Roll - Rebuilt 3.15" x 120" capacity - new condition
• DAVI 3-Roll CNC Hydraulic Plate Roll never used 8" x 120" capacity - still in original crates
• BERTSCH 3 — Roll Hydraulic Plate Roll 4" x 144" capacity - good condition
Email: sales@penncomachinery.com Ph: 717/569-0420
STEEL • ALUMINUM • STAINLESS
Are you having difficulty sourcing your requirements for coil, sheet or plate?
Let Metal Resources Inc. reach hundreds of service centers/stocking locations for you.
PH: 954/424-6664 • metals@gate.net
www.metalresourcesinc.net
BUSINESS OPPORTUNITIES
TUNGSTEN CARBIDE
American Machine Tools, Inc.
• Metalworking Lathes • CNC
• Shears
• Hand Brakes
• Press Brakes
• Ironworkers
• Bending Rolls
• Saws
• Grinders
• Line Boring Tools
www.AmericanMachineTools.com
773/334-5000
Progressive Die Design FourslideTooling Design
SolidWorks • Logopress3
Phone: 1-270-684-1050
Explore past issues
of MetalForming magazine on the Internet!
Check out MetalForming Xtra www.metalformingmagazine.com
50 MetalForming/June 2013
www. carbidewiredies
.com
