Page 13 - MetalForming July 2013
P. 13
Zero-Drip Nozzle
Eliminates
Lubrication Waste
Industrial Innovations, Wyoming, MI, introduces its Z-nozzle, a zero-drip noz- zle with magnetic base that secures it tightly to its mount, yet can easily be moved and repositioned as needed for various applications. The Z-nozzle is 99.5-percent drip-free, helping to elimi- nate costly waste in lubricant application. Designed to work with the firm’s Spra-Rite spray lubrication system, Z-drip spray noz- zles combine low pressure with high velocity.
RP, from Tower Oil & Technology, Chicago, IL. The synthetic, oil free, nonflammable and nontoxic liquid promises to make removal of slag easier, reducing machine downtime and maximizing equipment efficiency. Spray or paint a light coating of the liquid on cutting-table slats and areas where buildup is a concern.
Kleneslat-RP does not contain sili-
cones or ozone depleting chemicals; will not inhibit secondary operations such as welding, painting or galvanizing; and its ingredients are carefully select- ed to not cause hazardous fumes or dis- comfort to operators and surrounding workers.
Tower Oil & Technology Co.: 773/927-6161; www.toweroil.com
Max O’Dee
MAXIMIZE PRODUCTION with CHS Automation
Since 1966, CHS Automation
has been assisting the metal forming industry by providing a productive edge in press room operations. Our products range from servo roll feeds to highly automated coil processing lines.
CHS Automation can design and build a system to meet your requirements, including component machinery to upgrade your existing equipment.
Complete coil handling systems Servo roll feeds
Coil reels / Un-coilers
Coil straighteners
Scan here to see our machines in action! http://bit.ly/ chsvideos
For all your coil handling needs, email Max O’Dee! max@chsautomation.com www.chsautomation.com
Yesterday’s Integrity. Tomorrow’s Technology.
16660 Thirteen Mile Road | Roseville, MI 48066 Phone: 586-777-7440 | Fax: 586-777-4663
Fluid application is controlled through pressure, time, degree of pattern and electronic programming of a simple HMI. The design provides easy interchange- ability of the spray tips for a variety of spray angles and volumes. For example, at 40-PSI water pressure, flow is 0.1 gal./min. at a 25-deg. angle; 0.2 gal./min. at 65 deg.; and 0.4 gal./min. at 110 deg.
The spray nozzles are available in brass, stainless steel or plastic, with tub- ing choices of 1⁄8-, 3⁄16- and 1⁄4-in. dia. Industrial Innovations: 616/249-1525; www.industrialinnovations.com
Sticky Thermal- Cutting Slag a Drag?
Metalformers fighting a losing battle with hot slag and spatter sticking to support slats and workpieces during laser, plasma or flame-cutting operations have another soldier to enlist: Kleneslat-
MetalForming/July 2013 11
C
