Page 12 - MetalForming August 2013
P. 12
ENGINEERED for success.
DELIVERED ON TIME.
Associated Spring Raymond is your leading source for complete custom or catalog solutions. We have the base technology, largest product breadth, industry firsts, global distribution network, and engineering expertise to offer multiple solutions to an application’s functional envelope. Choose Associated Spring Raymond for precision
engineered solutions; the right force, pressure, counter-balance, linkage,
and or mounting isolation for your application.
www.asraymond.com Tel: 800.872.7732
Fax: 800.350.6203
News Fronts
setup data or job-number selection.
Hydraulic Coining Press to Manufacturer of Brake Parts
Greenerd Press & Machine Co., Inc., Nashua, NH, has delivered a 1000- ton hydraulic coining press to the South Bend, IN plant of Global Parts Networks, LLC (GPN). GPN manufac- tures brake shoes, brake- shoe kits, friction material and related parts for tractor trailers and heavy-duty trucks.
The press is the firm’s second from Greenerd; both are used to coin remanufac- tured brake shoes in a sin- gle-stroke hand-fed opera- tion. It’s an eight-point gib-guided press with a 36- by 36-in. bed, 28 in of day- light, 12-in. adjustable stroke and pressing speed to 23 in./min. A pre-slowdown cir- cuit allows the operator to set the height for changeover from rapid-advance to press- ing speed.
Neff Press Installs Deep-Draw Filter-Can Line
Baldwin Filters, Kearney, NE, a manufacturer of com- mercial-truck, off-road and industrial filters, has installed a new deep-draw can-making line from Neff Press, St. Louis, MO.
Baldwin senior manufac- turing engineer John Macran- der and Neff Press chief engineer Jon Schmidt will provide a technical presenta- tion on the line during the FABTECH 2013 education program, at a Deep Draw Technologies track on Thurs- day, Nov. 21, from 8 to 10 a.m. The case study will
include basic information on deep-draw technology, and explain the line’s high-speed servo-hydraulics, quick die change, automated blank handling, in-die sensing and servo transfers. FABTECH runs November 18-21, 2013 at McCormick Place, Chicago, IL.
Awards
Boeing Awards Metal Distributor Supplier of the Year
TW Metals, Inc., Exton, PA, earned Supplier of the Year recognition from The Boeing Company, in the Common Aerospace Com- modities category—one of 16 companies honored for distinguished performance in working with Boeing.
The metal distributor supplies extrusions, fit- tings, pipe, tube, sheet and other products in several materials including mild, alloy and stainless steels, and aluminum and nickel alloys. It delivers to Boeing production facilities several times per day using a just- in-time cut-to-length program.
Certifications
Precision metal stamper Wiegel Tool Works, Wood Dale, IL, has been regis- tered to ISO 14001:2004, which specifies the require- ments for an environmental- management system. The ISO 14000 family of stan- dards helps organizations minimize their impact on the environment and comply with applicable laws and regulations. Wiegel Tool Works manufactures tight-
10 MetalForming/August 2013
