Page 52 - MetalForming August 2013
P. 52
Classifieds
PRESS REBUILDING
EQUIPMENT FOR SALE
INDUSTRIAL MACHINE REPAIR
N Field Millwright Services N Welding & Brazing
N Heavy Machining
N Press Inspections
N Clutch and Brake Retrofits
N Consultation Services
N Used Parts & Rebuilt Presses
For Sale
Phone: (812) 346-2216
6,000 ton Hitachi Zosen
(USI Clearing) S2-6000-1100-200 Long Chassis
Simultaneously bends & forms up to 36 feet long Chassis’
Still installed, this press is immediately available!
TrueForge Global Machinery Corp
Ram stroke – 20”
Height between the bolsters – 55” Bed dims – 36 ft x 3 ft
Ram adjustment – 14” Continuous Strokes per minute – 10 Single strokes per minute – 7
Coil Handling and Press Feeding Equipment In Stock Remanufactured/Reconditioned
• Servo Roll Feeds • Coil Feed Lines • Coil Straighteners • Coil Reels
Servo Roll Feed Control Retrofits
In Stock:
Minster Coil Feed Line 20,000 Lbs. x 50"
Wide x .060"
Coe Press Coil Feed Line 20,000 Lbs. x
42" Wide x .125"
Dallas Servo Roll Feed 24" Wide x .290"
Pneumatic Feed Service
586/774-6675
www.pressfeed.com
DIES • DESIGN/BUILD
American Machine Tools, Inc.
• Metalworking Lathes • CNC
• Shears
• Hand Brakes
• Press Brakes
• Ironworkers
• Bending Rolls
• Saws
• Grinders
• Line Boring Tools
Progressive Die Design FourslideTooling Design
SolidWorks • Logopress3
Phone: 1-270-684-1050
www.AmericanMachineTools.com
773/334-5000
NEW Roll Former Double Layer With Automatic PBR-R Panel
Specifications:
• Chain Transmission
• CR12 Heat Treated Blade Material
• 36'-45'/min Rollforming Speed
• 0.4-0.8 mm (.016"-.0315") Thickness
• 16 Rollforming Stations
• 70mm Shaft Diameter
• #45 Steel Shaft Material
w/quality adjustment
• 3 KW Hydraulic Station
• High Quality Japanese Bearings
The system comes complete with uncoiler, cold former and hydraulic shear.
Lalani Steel USA • Ali Nathoo anathoo@lalanisteelusa.com 909.463.3307 Ext 114
LUBRICATION
MicroSpray Systems Roller Coater Systems Spray Cabinets Airless Spray Systems
Computer Controlled Systems
email:sales@lspind.com 800-577-7895
www.lspind.com
Metal Stamping
Lubrica
tion Solutions
Since 196
4
33 TON HYDRAULIC C-FRAME PRESS
Demonstrator – Low Price – New Machine Guarantee
• C-frame & straight-side presses
• 3' & 5' x 66 & 110 ton press brakes
• 220 & 330 & 440 ton multi-axes presses • Tank-head dishing machines
• Angle & sheet & plate bending rolls
COLE-TUVE, Inc. info@coletuve.com • 800-989-0700
Explore past issues of MetalForming magazine
on the Internet! Check out MetalForming Xtra www.metalformingmagazine.com
50 MetalForming/August 2013
Classified ads get results. Call Sue to place your ad. 216/901-8800 ext. 2131
