Page 15 - MetalForming September 2013
P. 15
lasers. The advantage of laser-blanking lines: no need to invest in and maintain, and the blanking operation avoids time-con- suming and costly delays during die changes.
Enter new coil-fed laser-blanking technology debuted recent- ly by Schuler at the facility of diode-laser manufacturer ALS GmbH, in Dormagen, Germany. Dubbed DynamicFlow Technology (DFT), the line allows “even small batches to be produced just-in-time at low cost,” says Stephan Mergner, Schuler Automation man- aging director.” Not only can the line be used to simultaneous- ly produce a wide variety of blank shapes, but blank contours also can be optimized while production is running. “The result: High output rates and tremendous flexibility,” adds Mergner.
QUICK DIE CHANGE SUCCESS!
Now Introducing
MAGNETIC QUICK DIE CHANGE:
without retooling
clamping force reduces tool wear
sizes.
HYDRAULIC DIE CLAMPING:
Hilma has been safely clamping dies for more than 50 years. We specialize in die change systems that maximize the output of your specific press. We stand behind our products, and provide you with the excellent service you need to remain competitive in today’s manufacturing environment.
Bars
View stamping products at: www.clrh.com Ellisville, MO 63021
(636) 386-8022
Visit Us At FABTECH Booth S4538
DFT laser-blanking lines are energy-efficient and can process a variety of materials, including high-strength steels, with a high degree of repeat accuracy and edge quality, says Mergner. The process also suits the production of surface-sensitive outer panels.
During the presentation at ALS GmbH, customers primari- ly from the automotive industry witnessed how the line cuts blanks from a continuous aluminum coil. The laser-blanking line employs three laser heads in parallel to cut blanks from material 0.8 to 3.0 mm thick, to 2150-mm wide.
Schuler: www.schulergroup.com
MetalForming/September 2013 13
PROFITABLE AUTOMATION FOR HYDRAULIC AND MECHANICAL PRESSES
Turn every tenth of
a second into money
For AP&T, automation is a matter of moving sheet metal from one point to another as quickly
as possible. Things are always faster
with the right automation – and tim
e
is money. Visit us.aptgroup.com to see how you can transform your
c small time margins into big buc
k
s
m
e
r
r
o
k
s
