Page 29 - MetalForming September 2013
P. 29
Conveying Solution
Laser-cut parts—some of which are formed in press brakes—route to one of several manual weld booths at Virnig. “Fitup tolerances with the laser-cut parts are as tight as 0.002 in.,” says Dean Virnig. “That’s a vast improvement from the 0.05-in. tolerances we were getting with plasma, and results in as much as a 10-percent decrease in weld time.”
(also with a 6000-W CO2 resonator, and with a maximum sheet size of 1500 by 3000 mm).
The BySprint Pro features upgrad- ed piercing and cutting technology, and significantly greater acceleration pierce-to-pierce, which Virnig believes will really pay off when processing its more hole-intensive sheet nests. Max- imum acceleration is 12 m/sec.2 (com- pared to 3 m/sec.2 with the Bystar 4020), and maximum velocity is 140 m/min. (85 m/min. with the Bystar). “We’ll leave the nests with fewer pierces and that require fewer non- cutting moves to the Bystar,” Virnig says.
And yes, Virnig also equipped his newest laser-cutting machine with a Mayfran shuffle-drive conveyor under- neath and an elevating conveyor to move material up and out to a bin. He again notes that “since the operator doesn’t have to empty part drawers, he’ll be able to tend to both cutting machines.” MF
A FAMILY OF PERFORMERS SINCE 1946
Rousselle presses are offered in single point gap, two-point gap, two-point straight side and adjustable bed styles from 15-400 tons. All presses carry
THE HEIM GROUP reputation for American-made design, engineering and quality to your operation. Competitively priced and backed by an unmatched package of service, fast part delivery and even custom modifications to standard models, so the press you buy is the press you really need. LET HEIM HELP!
Visit www.theheimgroup.com today for the whole story!
Can’t wait? Call 1-800-927-9393
DIE CAD GROUP
“Designing for the Future”
Designers of Progressive, Line and Transfer Dies
3D Catia UG/Catia Surfacing
Finite Element Analysis using PAM STAMP software
2D AutoCAD
3258 Clear Vista Court NE Grand Rapids, MI 49525 Ph: 616-365-2454 Fax: 616-365-1135
www.diecadgroup.com
cad@diecadgroup.com ISO 9001 Certified
See Us At FABTECH Booth 4363 27
H
