Page 41 - MetalForming November 2013
P. 41
Tooling by Design
occurred during the stamping process. The strip is the equivalent of an eye- witness of a car accident. Like the wit- ness, the strip was physically present during the entire process, and experi- enced everything that occurred. It knows, for example, if:
• The material fed properly.
• The pilots accurately positioned the strip.
• Pitch length (the distance between pilot holes) grew or shrunk beyond spec.
• A stretch flange split due to a mis- matched cut.
• Extrusions split due to a burr.
• The die is hitting too hard or not hard enough.
• Deep-drawn features split due to restricted material flow or an incor- rect radius.
• The carrier design is appropriate.
• The die is hitting level in all sta- tions.
• Die timing is correct with the die fully loaded.
• Cutting clearances change with the die fully loaded, due to tipping moments.
Press shops also must monitor tool wear and fatigue—breakage not caused by a die crash—and implement pre- ventive-maintenance programs to avoid wear-related instability.
Finally, don’t overlook how changes in process temperature affect linear expansion of press members and die components. A press structure will change size as it warms to its normal operating temperature on a cold morn- ing, or when it cools during a long repair or lunch break. In-die process heat, due to friction, can change the charac- teristics of punches and die sections by altering their size and clearances. When the press structure and die com- ponents change shape, the parts that they produce surely will be affected.
Achieving consistent part quality relates directly to how well the stamp- ing process inputs are understood and, most importantly, how well they are controlled. MF
ch
hi
in
ne
er
ry
y•
•S
St
ta
an
nd
da
ar
rd
& Supplies • 24/7 Service • Process Training • Repairs • Control Upgrades • Water Chillers
Resistance Welding M
Ma
ac
d&
&S
Sp
pe
ec
ci
ia
al
lD
De
es
s
si
ig
gn
n •
• N
Ne
ew
w &
& U
Us
se
ed
d •
• P
Pa
ar
rt
ts
s &
DIVERSE CONSUMABLES INVENTORY
STANDARD & SPECIAL DESIGN RESISTANCE WELDERS
Hot Press
Your daily source for news of the metalforming industry
off the
MetalForming/November 2013 39
Helpingcustomerssucceedwith resistance welding for 50 years
www.tjsnow.com | 1-800-NOW-SNOW | welders@tjsnow.com
