Page 32 - MetalForming January 2014
P. 32
Advertorial
TECH Buzz
Standard to Custom and Everything In Between
All Magnum hydraulic presses are designed, machined and assembled at the U.S. Magnum factory to pro- vide years of trouble-free service in your plant. With 155 standard hydraulic press models from 2 to 250 ton, Magnum Press Inc. has one of the most complete lineups of bench- top and floor-mount C-frame presses in the industry. Magnum also manu- factures a wide variety of hydraulic precision post guided presses custom built to the customers’ exact require- ments. These presses feature rugged 2- or 4-post frame construction and they are available with or without one or more moving platens. Each Magnum press features a dedicated frame designed and optimized to the tonnage of the press. Magnum struc- tural designs undergo rigorous analy- sis through FEA design testing. Die
cushions, indexers, up-acting designs, ejectors and other features may be added. Magnum hydraulic and electrical systems are designed for hydraulic presses. The Magnum philosophy is to build simple, reliable and easily serviceable systems utiliz- ing standard off-the-shelf hydraulic and electrical components that can be purchased from Magnum or from your local fluid power or electrical component supplier. With more than 35 years of press engineering experi- ence, Magnum is positioned to cre- atively analyze your application and provide the press you need.
Magnum Press, Inc.
Jerseyville, IL 62052 618/498-7077 www.magnumpress.com
Advertorial
TECH Buzz
Global Leadership in Advanced Abrasive Waterjet Technology
With a worldwide reputation for innova- tion, Omax Corporation leads the way in the design, manufacture and support of extreme- ly fast, highly precise multi-axis abrasive waterjet solutions that cut an endless amount of 2D and 3D parts from all types of materials and thicknesses.
Through its comprehensive product port-
folio, which includes Omax and Maxiem
waterjets, high efficiency direct drive pumps,
robust accessories and the world’s best
abrasive waterjet software, Omax Corporation offers everything a manufacturer needs to run highly productive and profitable metalworking operations in today’s com- petitive marketplace.
Headquartered in Kent, WA, Omax Corporation has the largest in-house waterjet systems research and devel- opment team in the world, allowing the company to con- tinuously advance its technology to meet the diverse and changing needs of its customers.
With a global service and support network in more
than 50 countries, Omax and Maxiem customers have engineering expertise, applications development, spare part services and training opportunities in close proximity to their operations.
Omax Corporation
21409 72nd Avenue South Kent, WA 98032 800/838-0343 | 253/872-2300 www.omax.com
30 MetalForming/January 2014 www.metalformingmagazine.com
