Page 12 - MetalForming March 2014
P. 12
Fast and Flexible Part-Transfer Solution for High-Speed Press Automation
ABB Robotics, Auburn Hills, MI, has introduced the Twin Robot Xbar (TRX) fast and flexible parts-transfer system, designed to handle large panels in tandem-press lines at a maximum output rate of 16 parts/min. Retrofit the transfer system to existing press lines without requiring additional space.
Utilizing two robots optimally distributes power and load, while minimizing the iner- tia in demanding press automation applications. Using ABB’s MultiMove technolo- gy, a single robot cabinet controls all ten TRX axes—two four-axis robots plus two crossbar axes. This simplifies programming without adding to the system footprint.
The system can accommodate a range of crossbar types and lengths to ensure the right fit for different line con- figurations. Crossbar changes for new pro- duction have been fully automated on the press bolster or at the interpress.
“The TRX can tilt in three different axes and allows dynamic reconfiguration of part distance when moving double parts (side- shifting),” says Enrique Pano, ABB Robot- ics’ press automaton manager, “elimi- nating the need for additional actuators.”
The TRX runs on ABB’s proprietary StampWare software package designed to facilitate interaction between opera- tor and press cell. Available on the robot FlexPendant for optimum simplicity, flex- ibility and cost effectiveness, Stamp- Ware includes a graphical programming wizard that helps operators program the robots without having to master the programming language.
ABB Robotics: 248/391-9000; www.abb.com/robotics
BEVELING TOOLS FOR WELD PREPARATION
From handheld tools to stationary machines,our equipment will give you an edge on beveling.
• Up to 10 times faster than grinding
• Consistent straight or rounded beveled edge along any contour
• Wide variety of machines application
• Many choices of angles and radii • No unhealthy grinding dust
859.331.8770 www.shmusa.com
10 MetalForming/March 2014
