Page 15 - MetalForming April 2014
P. 15
“The Energy Department and its national labs are forging partnerships with the private sector to strengthen advanced manufacturing, foster innovation and create clean-energy jobs,” says David Danielson, Assistant Secretary for Ener- gy Efficiency and Renewable Energy.
The partners will start by incorporating AM technology with the machine base of Cincinnati’s laser-cutting system, creating a prototype, large-scale AM system. The research team will then integrate a high- speed cutting tool, pellet-feed mecha- nism and control software into the gantry system to offer additional capabilities.
Pneumatic Die Lifters for T-Slots
PFA, Inc., Germantown, WI, has devel- oped pneumatic die-lifter rails for use in standard 3⁄4- and 1-in. T-slots. Designed for quick-die-change operations, the rails
come in an unlimited variety of lengths and provide a low-cost, easy-to-order and simple-to-install option in stand- alone or integrated applications.
PFA’s wide (1.000 in. at neck) and nar- row (0.800 in. at neck) pneumatic die lifters (with cam rollers) offer a lift capacity of 2600 lb./ft. per pair and 1800 lb./ft. per pair respectively, at 85 PSI shop air. The lifter rails fit in slots
as shallow as 1.250 in.
Using shop air eliminates the need for
hydraulics and the associated com- plexities of adding hydraulic systems to the press. Actuate the lifters using either simple hand-operated air valves or electronically operated valves integrated with other press controls.
PFA, Inc.: 262/250-4410; www.pfa-inc.com
A FAMILY OF PERFORMERS SINCE 1946
Rousselle presses are offered in single point gap, two-point gap, two-point straight side and adjustable bed styles from 15-400 tons. All presses carry
THE HEIM GROUP reputation for American-made design, engineering and quality to your operation. Competitively priced and backed by an unmatched package of service, fast part delivery and even custom modifications to standard models, so the press you buy is the press you really need. LET HEIM HELP!
Visit www.theheimgroup.com today for the whole story!
Can’t wait? Call 1-800-927-9393
Unrivaled Speed & Accuracy Driven by Nexen.
The Nexen Roller Pinion System makes the Pinnacle Whistler HP Plasma Cutter faster and more precise than rack and pinion, ball screw and belt driven systems. Get the same advantage for your machine.
• Speeds up to 36 ft/sec
• Less friction and wear
• Positional accuracy to
±.000118"
• Zero backlash
Learn more at nexengroup.com or call 1.800.843.7445
MetalForming/April 2014 13
