Page 44 - MetalForming August 2014
P. 44
42
MetalForming/August 2014
Don’t let the precision die components be the piece in your manufacturing puzzle that prevents you from keeping your lines
up and running.
Automation Details Ball Lock Buttons
a
H
Headed and Headless Die Buttons
Magnetic Tools & Conveyors Boost
Output Saving Time and Labor MagLifter
Contact us today for all your precision tooling for stamping, roll forming and metalforming.
800.243.1492
www.AmericanPunchCo.com • info@AmericanPunchCo.com
buntingmagnetics.com ©2013 Bunting® Magnetics Co.
Unrivaled Speed & Accuracy Driven by Nexen.
The Nexen Roller Pinion System makes the Pinnacle Whistler HP Plasma Cutter faster and more precise than rack and pinion, ball screw and belt driven systems. Get the same advantage for your machine.
• Speeds up to 36 ft/sec
• Less friction and wear
• Positional accuracy to
±.000118"
• Zero backlash
Learn more at nexengroup.com or call 1.800.843.7445
Close Loop Hydraulic Cushion from Red Stag
RSE builds new hydraulic presses up to 20,000 tons, rebuilds hydraulic presses, manufactures up to 400,000 lbs capacity carts and provides turnkey automation solutions.
Red Stag Engineering & Automation, Inc.
www.redstag.com (715) 258-5074
email: Paul@redstag.com
B
B
all Lock Retainers • Blade Punches Cut-off Dies • Die Inserts
Die Components Headed Punch Retainers Headed and Ball Lock Punches
Sheet Fanners
Upstacker Pulleys
(800) 835-2526
ustom Details • Roll Form Details C
C
u
Standard Frame Conveyors
Magnetic Assemblies
MagSlide Conveyors
