Page 14 - MetalForming September 2014
P. 14
stands ready to perform a multitude of tasks from rough grinding and blending to polishing to a mirror finish. Varilex comes standard with a 5-in. safety guard. Option- al guards come in sizes 4.5 and 7 in.
can dramatically reduce noise level. The tool’s motor features feedback technolo- gy that maintains constant power output and torque regardless of speed, helping to ensure a uniform finish.
to change discs in seconds without tools. An ergonomic, vibration-reducing bal- anced handle allows fatigue-free grinding, and the quick-lock-style power cord allows for easy tool changes.
CS Unitec, Inc.: 203/853-9522; www.csunitec.com
3D Waterjet Cutting
with Endlessly
Variable speed control, among other benefits, can double the service life of the abrasive disc, prevent glazing of the disc and heat deformation of the workpiece, and
Designed and developed for heavy industrial use, Varilex wheels come equipped with an easy-lock clamping nut and spindle-lock button, allowing the user
        GREENDALE PRECISION SERVICES
DC53 Punches
a steel for the 21st Century
        WWW.GPSPUNCHES.COM
Rotating Cutting Head
Hydro-Jet waterjet cutting systems from Knuth, Lincolnshire, IL, now can be option- ally equipped with a five-axis cutting head. The cutting head is based on the design principle of the Nutator—the two axes of rota- tion are at a 45-deg. angle to each other: When the cutting head rotates around the
 12 MetalForming/September 2014
Z axis, rotational movements of the cutting head do not cause a change in tool posi- tion. The advantage: for a change of water- jet direction, no compensatory movements of the linear x-y-z axes are required. A special rotary element allows a continuous feed of the abrasive sand.
Maximum angle of inclination: + 51 deg. And, the cutting head provides advan- tages for 2D cutting: Taper compensa- tion is automatically calculated, increas- ing system efficiency.
Knuth Machine Tools USA, Inc.: 847/415-3333; www.knuth-usa.com
   12   13   14   15   16
