Page 28 - MetalForming September 2014
P. 28
Rapid Die Changes
  Force from the magnetic clamping system comes through the poles surround- ed with the blue resin. The poles are distributed to hold the smallest tools as well as the largest tools.
hydraulic or mechanical clamps were used.
For the lower tool, though, magnets were not an easy
option. With the tools on paral-
lels, it was possible to clamp with magnets, but the investment would be much higher than if the tools were on plates. The number of tool changes per shift in this application did not justify the cost to use the more expen- sive magnetic clamping required for parallel-mounted tools.
And, because clamp height varied by as much as 1 in. from tool to tool, hydraulic clamps were not possible without substantial tooling changes
BELOW THE HOOK
burg, VA) with 13,400 lb. of clamping force and height-adjustable from 3.5 to 7 in., which eliminated the need for separate height heel blocks. Their design allowed a wide clamp-height range by adjusting the height of the bolt which passes through the forged
that meant higher costs.
That left mechanical clamps, which
have seen recent noteworthy upgrades in technology. For its new Aida press, Atlas went with adjustable mechanical clamps (Model S40 clamps from Lenzkes Clamping Tools, Christians-
ALL TYPES
Roll Lifters
     LIFTERS
 • STANDARD and CUSTOM
• DESIGN and MANUFACTURE
 Pallet Lifters
Models In Stock!
 NEED CUSTOM LIFT BEAMS — FAST? The Tandemloc Rapid-Ready® Program
Coil Lifters
Narrow Coil Models In Stock!
   Prices Quoted Instantly on the Phone — No Waiting!
Ships 5-7 Work Days of Order!
ONLY TANDEMLOC HAS IT!
Capacities to 26,000 Lbs.
Proof Tested to 125% Capacity!
Fully Compliant to ASME B30.20 2010 Standards.
MORE INFORMATION &
BUY ONLINE!
Manufacturing in the USA
      Buy Direct From the Manufacturer & Save!
    TANDEMLOC 30 YEARS IN BUSINESS!
www.TANDEMLOC.com Call Toll-Free: www.TANDEMLOC.com 1-800-258-7324
Tel: (252) 447-7155 • info@tandemloc.com TANDEMLOC, Inc · 824 Highway 101 · Havelock, NC 28532
 See online videos!
    26 MetalForming/September 2014
   26   27   28   29   30
