Page 12 - MetalForming October 2014
P. 12
News Fronts
LamCam Universal Cams
Anchor Lamina introduces a new style of compact cams
Same common footprint with other major manufacturers
Fabricator to Open Big-Time Powder- Coating Facility
cut electrochemical tube-cut- off machine from Everite Machine Products Co., Pennsauken, NJ. Superior Tube provides welded and seamless tubing from stain- less steels and nickel, zirconi- um and titanium alloys for numerous applications, including aerospace engines, heat exchangers, condensers and for medical use.
Chief Fabrication, Grand Island, NE, a division of Chief Industries, will soon open a new powder-coat facility said to be one of the largest in the United States. The facility, capable of applying primer and top coat in one pass to parts as long as 17 ft., fea- tures a 170-ft. seven-stage stainless-steel cleaning system and 1300-lb. part capacity. Line speed peaks at 12 ft./min.
Medium-Frequency RSW Machine a Hit at Marlin Steel
Contact your local Dayton Lamina Regional Manager or Authorized Dayton Lamina Distributor to see how much you can save with LamCam® Universal Cams.
13 series of Aerial & Die Mount Universal Cams
Covers all applications from Low Volume Light Duty to
High Volume Heavy Duty
Cam features: Choice of single or double wear plates for ease of maintenance
V guidance for precision guiding
Choice of mechanical or nitrogen spring return
Available globally
Technical support on all cam products
Anchor Lamina makes it easy to design. Grab a catalog and CAD files now.
800-652-6462
catalogs@anchorlamina.com www.daytonlamina.com/f39
See us at FABTECH 2014, booth B1101 a MISUMI Group Company
Bill Huizenga, U.S. Repre- sentative for Michigan’s 2nd congressional district, paid a visit to lubrication- and automation-system manufac- turer Industrial Innovations on August 25, 2014. His aim: to discuss with owner Troy Turn- bull and others how Congress can help boost U.S. manufac- turing competitiveness through legislation. Turnbull and Con- gressman Huizenga first met during a government-advocacy program in Washington, D.C, in March 2014, produced by the One Voice advocacy program. One Voice, with some 3000 member companies, was cre- ated by the Precision Metal- forming Association and the National Tooling and Machin- ing Association.
Industrial Innovations Hosts U.S. Congressman
An Ideal (based in Ger- many and with U.S. operations in Rockford, IL) robotic medi- um-frequency resistance-weld- ing machine has been installed at Marlin Steel Wire, Baltimore, MD. The machine, a Versaweld model touted as only one of five in the world and the only one outside of Germany, supports welding in three dimensions. It features rotating heads that can weld along curved or irregular shapes and completes welds in 0.002 sec. Its worktable measures 4 by 10 ft.
10
MetalForming/October 2014
Tube Manufacturer Invests in Electrochemical Machining
The National Institute for Metal Working Skills (NIMS) has created the GHF-NIMS Credentialing Scholarship Pro- gram, funded initially by a $100,000 grant from the Gene Haas Foundation (GHF). Grants will be made to eligible secondary and post-second- ary institutions to help build high-quality technical pro- grams. GHF provides scholar- ship funding to help students attend colleges that teach machining-based skills.
Superior Tube Co., Col- legeville, PA, a manufacturer of small-diameter precision tubing for safety-critical appli- cations, has acquired an Ultra-
Gene Haas Foundation Funds NIMS Scholarship Program
