Page 58 - MetalForming October 2014
P. 58
Previews
Tube Cutting and Bending Technology
BLM Group USA Booth C922
BLM Group, a
manufacturer of
tube-processing
solutions, will dis-
play its wide range
of equipment at
FABTECH, including its LT8
machine and an array of other tube-fab- ricating equipment. The LT8 is a three- dimensional laser tube-cutting machine that provides extremely precise laser cut- ting on tube diameters from 12 to 220 mm and bar weight to 35 kg/m. The unit’s rotat- ing head provides for five-axis cutting and features an automatic loading system combined with a unique unload, increas- ing the productivity of most operations. Complex processing such as cutting dif- ferent pieces on the same bar or batch changing among bars is managed auto- matically.
laser tube-cutting system designed to handle small and medium-sized tubes. Thanks to the versatility of its advanced 1-kW IPG fiber laser, the LT5 can effi- ciently process mild steel as well as high- ly reflective materials such as aluminum, copper and brass. The system’s fiber laser provides a dramatic improvement in energy efficiency when compared to the more traditional CO2 laser, leading to as much as a 50-percent reduction in hourly operating costs.
Tube benders on display include the all new 4Runner designed specifically for HVAC applications; the Elect all-electric tube bender; and the ETurn right-hand, left- hand all electric tube-bending machine. The Elect all-electric 12-axis bending machine handles large tubes to 150-mm dia.
www.blmgroup.com
Information also will be available on the LT5 (shown), an entry-level automated
The only global tailored solution provider specializing in: Steel
Tailor Welded Blanks, Tailor Welded Coils , Hot Formed Tailor Welded Blanks, & Aluminum Tailor Welded Blanks
Steel Tailor Welded Blanks
Reduce weight, improve performance & costs
Combine all steel grades Part Consolidation
Steel Tailor Welded Coils
Used in coil fed operations Vary gauge, grade, &
coating across coil width
Complete Ablation Combine PHS to PHS
or HSLA
Mix alloys & thickness 5000, 6000, & 7000
series alloys
Material Utilization
TWB Company
56
MetalForming/October 2014 www.metalformingmagazine.com
