Page 62 - MetalForming October 2014
P. 62
Previews
Arc-Welding Guns for Semiautomatic
and Robotic Applications
Combo Clutch-Brakes
on Display
Orttech Booth B1410
Bernard, Tregaskiss Booth C2944
Bernard and Tregaskiss
will share a FABTECH 2014
booth, showcasing Bernard’s semiautomatic gas- metal-arc-welding (GMAW) guns and consumables, and Tregaskiss’ robotic GMAW guns, consumables and peripherals.
Orttech will showcase the latest mod- els of its Ortlinghaus hydraulic combina- tion clutch/brakes. The oil shear tech- nology these products
utilize enables them
to operate virtually maintenance-free
and provide opti-
mum perform-
ance for stop-
ping times,
press speeds
and single-
stroking
r a t e s .
Ideal for
new installa-
tions or con-
versions of existing machines, the clutch/ brakes are available in a wide range of sizes to fit any application.
www.orttech.com
Bernard’s new line of Best of the Best (BTB) Platform guns allows users to build their ultimate GMAW gun by choosing from an expanded list of the best features from the former Bernard Q-Gun, S-Gun and T-Gun lineup. The top features from each legacy gun line have been con-
solidated into a single gun with a
single online configurator.
Also on display will be the
Bernard Clean Air fume-extraction
gun, newly redesigned to allow welders a more comfortable
option for reducing harmful weld fume and smoke in their
work area. With a small and lightweight design, this new Clean Air gun has nearly the same dimensions as a regular Bernard semi- automatic gun and is ideal for most medium- to heavy-duty solid or flux- cored wire welding applications.
www.bernardwelds.com; www.tregaskiss.com
CUSTOMIZED SOLUTIONS
No two alike.
Each built for your unique application. This is the new Multipress.
614-228-0158, Ext. 231 osales@multipress.com www.multipress.com
60 MetalForming/October 2014
