Page 68 - MetalForming October 2014
P. 68
Previews
Universal Cam Line
tions from low-volume light-duty to high-volume heavy-duty. Cam widths are available from 50 to 600 mm, each with a footprint com- mon to other cam manufacturers.
Servo-Feed Press Feed Control
Dayton Lamina Booth B1101
Dallas Industries Booth B1560
Dayton Lamina will unveil its LamCam line of universal com- pact cams at FABTECH, ideal for piercing, flanging and trimming operations. With 13 series of aerial and die-mount universal cams from 0 to 75 deg, the comprehensive lineup covers all applica-
Dallas Industries, Troy, MI, will demonstrate its DRF-308 servo feed, equipped with its latest control technology, at FABTECH. The new control features three modes of operation in one pack-
LamCam universal cams are offered with single or double wear plates for ease of maintenance, and either mechanical or nitrogen spring return. A V-guidance system ensures precision guiding.
ProfileSelect uses a sinusoidal profile (cam motion) that pro- vides a smooth motion and material feed, utilizing 100 percent of the press-feed window while putting less stress on all mechanics. The process is ideally suited for progressive-die work when the part’s cosmetics are a factor, or when running deli- cate material. www.dallasindustries.com
www.daytonlamina.com
age—time-
based
servo-feed
synchro-
nization;
auto com-
pensation
for on-the-
fly increas-
es in press
speed; and
the unique ProfileSelect technology that minimizes electrical and mechanical stress on stamping equipment and materials.
The most reliable,easy-to-use Heavy-Duty Tool Changer. Ever.
A more reliable fail-safe.
A patented “springless” mechanical fail-safe is guaranteed to work, even with loss of air pressure.
A more reliable locking mechanism.
7,000 pounds of locking force guarantees that signals pass flawlessly, even with heavy accelerations and payloads.
A more flexible utility solution.
Widest choice of modules (power, fluid/air, signal, and more) with common mounting features for greater flexibility.
With patented advances in the locking mechanism and failsafe, and new flexible module mounting and integrated robot mounting patterns, we’ve created the most reliable, easy-to-use Heavy-Duty Tool Changers. Ever.
ATI’s Heavy-Duty Tool Changers have set a new standard.
www.ati-ia.com 919.772.0115
ROBOTIC END EFFECTORS
Booth B1650
66 MetalForming/October 2014
