Page 83 - MetalForming October 2014
P. 83
Only one automotive company is
TOUGH enough to build an aluminum- bodied truck.
Only one company is TOUGH & CAPABLE enough to build the machine to process the aluminum.
Servo-Driven Tail Out Feeder with Vacuum Belt for transfer application
Outboard Support Rails with powered adjustment
Powered Telescoping into die area
marking and build up
1” of Depth Engagement on straightening rolls for enhanced straightening capabilities
Four Pad Mandrel Design with wedge expansion to help prevent coil triangulation at end of run
Automatic Coil Centering via coil car and laser sensors
Recipe Driven Automatic job setup of multiple functions
For over 45 years, Feed Lease Corporation (FLC) has been committed to designing and building premium quality, high performance press room automation equipment.
From space-saving lines to custom and conventional lines that work with Class A and other surface-critical materials, count on Feed Lease to provide a smart and proven solution.
For more information, call
or visit us on the web at:
Maximum coil weight .......................................................... 40,000 lbs. Maximum coil O.D. ......................................................... 72”(1828mm) Maximum stock width ..................................................... 72”(1828mm) Maximum stock thickness* ............... .140” (3.8mm) @ 72”(1828mm) Minimum stock thickness* ................. .015” (0.4mm) @ 72”(1828mm)
.................................... Conventional Feed Line Accuracy at feed rollers to within.............................................. ± .003” Progression range ......................................................... 0 to 999.999” * Military-grade Aluminum Alloy
