Page 16 - MetalForming December 2014
P. 16
Feed Lines
can be a challenge with thinner mate- rials,” says Galuszka. “And, we expect that the larger bearing surfaces will prolong bearing life.
“To handle the delicate materials without leaving any marks,” Galuszka continues, “the rolls are coated with #5 Crodon, a better fit for our applica-
BELOW THE HOOK
Weber worked closely with CHS to pro- vide several feed-line features to meet its specific application-based require- ments. Among them is the dual-caliper failsafe braking system on the coil reel, shown here. The braking sys- tem is self-monitoring and auto-adjusting based on laser gauging of coil OD, significantly more operator- friendly than feed lines that require operators to constantly make adjust- ments.
tion than the more typical and heavier #3 Crodon coating that we felt could cause part marking.”
“The servo feed also features an adjustable-stroke cylinder for pilot- ing,” adds Lohbauer. “This allows us to adjust the pilot/feed roll travel to minimize roll lift based on the materi-
al thickness being stamped. And, the feeder includes a MultiMediaCard read- er. We can store all of the feed param- eters for each die on the cards as back- up should we need to change out the drive.”
What Else is Cooking?
With new Weber grill models intro- duced in 2013, and likely more coming soon, the pressroom hasn’t seen its last piece of new equipment, by far. Deliv- ered in late November and expected to be commissioned early in 2015: a new 800-ton Heim straightside press accompanied by another well- equipped CHS feed line.
“Better setups and changeovers, optimum material traction through the feeds and confidence that our stamped parts will exit the press lines flaw-free and aesthetically pleasing is what we’re after,” summarizes Galuszka. “And that’s exactly what we’re getting thanks to all of the special features and bene- fits of our pressroom equipment.” MF
ALL TYPES
Roll Lifters
LIFTERS
• STANDARD and CUSTOM
• DESIGN and MANUFACTURE
Pallet Lifters
Models In Stock!
NEED CUSTOM LIFT BEAMS — FAST? The Tandemloc Rapid-Ready® Program
Coil Lifters
Narrow Coil Models In Stock!
Prices Quoted Instantly on the Phone — No Waiting!
Ships 5-7 Work Days of Order!
ONLY TANDEMLOC HAS IT!
Capacities to 26,000 Lbs.
Proof Tested to 125% Capacity!
Fully Compliant to ASME B30.20 2010 Standards.
MORE INFORMATION &
BUY ONLINE!
Manufacturing in the USA
Buy Direct From the Manufacturer & Save!
TANDEMLOC 30 YEARS IN BUSINESS!
www.TANDEMLOC.com Call Toll-Free: www.TANDEMLOC.com 1-800-258-7324
Tel: (252) 447-7155 • info@tandemloc.com TANDEMLOC, Inc · 824 Highway 101 · Havelock, NC 28532
See online videos!
14 MetalForming/December 2014
