Page 34 - MetalForming December 2014
P. 34
Laser-Punch Combo
typical piece of sheetmetal traveled 1600 ft. before leaving the 75,000-sq.-ft. Winston plant. Assembly lines occu- pied the center of the 60,000-sq.-ft. factory (400 ft. long by 150ft. wide), surrounded by fabricating and other equipment located on the perimeter.
“Value-stream mapping led us to significantly alter the factory layout (in 2011), which shortened the average piece-part travel distance to just 550
ft.,” says Leavitt.
And, prior to reorganizing its
process flow, the plant had focused on reducing turret-press setup times and implementing offline programming. All told, by Leavitt’s calculations, the plant improved productivity by 15 per- cent by focusing on turret-press setup and programming, and another 15 per- cent when it reorganized its process flow. In 2012, with its initial laser acqui-
sition, productivity jumped another 3 percent; the SL4 and P4 additions added a whopping 19 percent to the plant’s productivity.
“That’s a 52 percent jump in pro- ductivity in just 5 yr.,” exclaims Leavitt. As if that’s not enough, Leavitt adds that material utilization has jumped considerably with the addition of the SL4, “primarily because the machine does not have to trim around the entire perimeter of the sheet,” he says. “It
S
only trims one side of the blank.”
As a result, material utilization jumped from 73 percent to near 90 percent. As Winston purchases more than $2 million worth of stainless steel per year, Leavitt estimates that the gain in utilization saves the firm more than
$230,000 annually.
“And, inventory held onsite has been
cut in half,” Leavitt adds, “freeing up a considerable amount of floor space.”
Fortifying Efforts to Diversify
Along with supporting inhouse needs for sheetmetal components, Leavitt sees opportunities to market the capabili- ties of the SL4 and P4 machines to other manufacturers. For example, Winston Industries, in addition to its catalog of foodservice equipment, also manufac- tures electronic circuit boards, cable and wire harnesses for several cus- tomers, through its Win2uit manufac- turing-services subsidiary. Leavitt says that as Win2uit customers visit Winston and witness the performance of the Sal- vagnini equipment, “they often ask us if we can fabricate their sheetmetal enclo- sures in addition to their electronic components,” he adds. “We’ve picked up 30 to 35 new sheetmetal-fabrication customers for our new equipment, pri- marily low-volume (up to a few hundred parts) quick-turnaround (3-4 days) work.
“Salvagnini has become an integral part of our production operations,” Leavitt concludes. “They’re connect- ed to the data stream coming from the machines and can see our production data, identify any hiccups and trou- bleshoot remotely, as well as perform software updates.” MF
S
E
E
R
R
I
I
E
E
S
S
G
Best Clamp in the Industry
Available with
Panel Present Detection
& Double Sheet Detection Clamp communicates when a panel or multiple panels are detected.
G
R
R
M
M
Series GRM Pneumatic Workholding Clamps
PHD’s Series GRM Clamps offer the
BEST switch technology available in the sheet metal handling industry
1-800-624-8511 ext.5
www.phdinc.com/mf1214
For a free catalog, visit:
32
MetalForming/December 2014
