Page 13 - MetalForming January 2015
P. 13
Automation for Fastener Installation
Autoriv ® A100 In-Die A turn-key in-die assembly system, engineered for high speed, consistent quality and maximum reliability. Various patented concepts provide a solution for almost any application using studs, nuts, j-nuts, bushings, ball studs and specials.
Autoriv ® A210-BI
A process monitoring system that can detect a bad
set fastener and ensure no missing fasteners. As an optional feature, it can also confifirm the fasteners are installed in the correct locations.
Autoriv ® A230-CP (for clinch type fasteners) A small compact C-frame, designed to be mounted on a robot with a built in tolerance-absorbing feature (patented). This system can be configured with Ethernet IP, Profibus and
DeviceNet. This system comes with a feeder that is mounte outside the ce
Autoriv ® A230-BI (for blind fasteners)
A robot-mounted system designed to be installed in robot cells where the robot positions the head so the automation can
install the rivet nut. It can communicate with PLC or a robot. Th system comes with a feeder that is mounted outside the cell an is available with optional process monitorin
Autoriv ® A240-CP (for clinch type fasteners)
A stationary C-frame setting system that is designed to incorporated into a robotic cell. This system consists of thr
main elements: The C-frame, a separate feeder that can be place outside the cell for easy filling, and a built in tolerance-absorbin
feature (patented) to ensure that the part being installed is accurately placed in the assembly
Autoriv ® A240-BI (for blind fasteners)
A turnkey, flfloor-mounted pedestal, designed to be installed
d robotic cells where the robot positions the part so the automat
i
i
n
n
can install the rivet nut. It can communicate with PLC or a rob This system comes with a feeder that is mounted outside the c
and is available with optional process monitori
www.mds-fs.com • 586-270-6399
