Page 22 - MetalForming January 2015
P. 22
Software for Manufacturing
from hours to minutes, say company officials.
For tube bending, the software auto- matically extracts key manufacturing infor- mation such as bend angles and rota- tions from a native SolidWorks model or a common CAD file, and creates the bend table for immediate use on a CNC bending machine, as well as the XYZ coordinates and a 2D drawing of the modeled tube. Ver- sion 2.6 of TubeWorks extends this func- tionality significantly, by enabling users to “unbend” the CAD models of bent tubes into flat (or straight) configurations con- taining full details of all holes and cutouts, to provide the input data for laser tube-cut- ting machines.
ifying the required length change and the point at which it should be applied. This compensates for the elongation shown by a coordinate measuring machine. Users then can create a new YBC file for the bend- ing machine and a new ParaSolid file for the laser-cutting machine. www.hornmachinetools.com
PLATE | SHEET | COIL | STRIP | NEAR NET SHAPES
As well as automating the extraction of manufacturing data, TubeWorks offers numerous functions to further help users minimize the preproduction design time of machine-based tube cutting and bend- ing. These include automated centerline creation through tubular geometry (for
round and non-round profiles) and auto- mated conversion of imported tube mod- els into native SolidWorks models for cen- terline-radius modification.
The latest version of TubeWorks also now offers an automated Deduct Length function that enables users to shrink flat- tened tube configurations simply by spec-
STAINLESS STEEL
17-4 PH 17-7 PH 301
301 1⁄4 301 1⁄2 301 FH
302 309/309S 304H 310/310S 304/304L 316/316L
321/321H 347/347H 410
825 Alloy X
Water Jet Cutting Laser Cutting Precision Sawing
We’re Your Specialist in Specialty Metals!
United Performance Metals is your source for high temperature, high strength, and corrosion resistant alloys. Our comprehensive inventory of sheet, coil, and plate can be processed to your exact specifications.
DUPLEX STAINLESS STEEL 2205
NICKEL ALLOYS
20 A286 601 718
263 400 617 X750 C-276 600 625 800H/HT
COBALT ALLOYS L605 188
FIRSTCUT+® Services
Precision Shearing
Hi-Definition Plasma Cutting
Cut-To-Length/ Leveling
Slitting Edging
Call 888.282.3292 for the Metal You Need and the Solutions You Want! www.upmet.com | sales@upmet.com
20 MetalForming/January 2015
