Page 24 - MetalForming February 2015
P. 24
FABTECH 2014—So Much to See, So Little Time to See it
Bigger Waterjet Machines
Meet Demand for Large-Scale Production
Among the several exhibitors of waterjet-cutting machines at FABTECH, Omax Corp., Kent, WA, showcased its expanded line of Maxiem JetMachining Centers. Omax introduced three larger machine sizes to meet the large-scale production
needs of OEMs, metal service centers and fabricators. The first five models in the next-generation Maxiem machine lineup, introduced in April 2014, featured pro- ductivity-enhancing features to meet customer demands for cost-efficient yet high- performance waterjet-cutting technology. The lineup now comprises eight mod- els, including the new 2060, 2080 (pictured here) and 3060 JetMachining Centers.
The 2060 and 2080 models cut work to 6 ft.-7 in. wide by 20 ft.-6 in. long, and 27 ft.-2 in. long, respectively. The Model 3060 boasts a wider work envelope, ideal for machining a wide range of materials and thicknesses, from metals and com- posites to glass and plastics. This machine features Y-axis cutting travel of 10 ft.- 2 in. and X-axis cutting travel of 20 ft.-6 in.
These JetMachining Centers also feature the Intelli-Trax linear drive system that
uses brushless servo motors, integrat- ed servo drives and precision linear encoders to provide constant and con- tinuous feedback on cutting-head position. www.omax.com
Compact Power Source Meets Output Requirements Ranging from Power-Intensive to Precise
On the value-added front, metal- formers were able to find plenty of new-technology offerings among the numerous welding-equipment dis- plays, including that of Miller Electric. Designed specifically to withstand harsh environments, Miller’s Dimen- sion 650 multiprocess
welding power
supply pro-
vides power-
intensive out-
put for heavy
welding and
carbon-arc
gouging, as
well as preci-
sion arc char-
acteristics
designed for thin
sheetmetal welding.
This compact and energy-efficient machine features a tough, corrosion- resistant, all-aluminum case.
The reduced size and weight of the Dimension 650 when compared to the legacy Dimension 652—3.5 times lighter and a 40-percent smaller foot- print—makes it easier to handle while still providing the welding perform- ance of a larger machine.
In gouging mode, the machine pro- vides 800 A of usable power, and 650 A at 100-percent-duty cycle.
www.millerwelds.com
Lightweight, Inverter-Based Power Source
Esab Welding & Cutting Products, Florence, SC, introduced the Aristo Mig 4004i Pulse power source to its family of welding equipment. The lightweight, multiprocess unit powers gas-metal- arc welding (GMAW) and pulsed GMAW, as well as gas-tungsten-arc
22
MetalForming/February 2015
ISO 9001 REGISTERED
LOOKIN’ FOR A ‘TWEENER?
Standard steel gauges are cake. What happens when you need that one crazy thickness that defifies all stocking lists? You call the pros at Admiral Steel. Our gauge correction process will squeeze out the necessary thousandths to arrive at your nominal thickness. The finish is preserved and you can ditch the grinder for this job.
Call, fax, or email and let us put the squeeze on your ‘tweener.
4152 West 123rd Street Alsip, Illinois 60803-1869 www.admiralsteel.com Ph: 800.323.7055 Fx: 708.388.9317 email: sales@admiralsteel.com Admiral is a registered trademark of Admiral Steel LLC. Alsip, Illinois. Reg. No. 2430959. All rights reserved.
