Page 25 - MetalForming March 2015
P. 25
via recipe (Fig. 5) to speed production changeovers and gain repeatability, which we didn’t have before,” says Shortridge. “We often have relatively small production runs where a spring may contain as many as 12 different
Power / Speed / Value Since 1937
leaves. In the old days, we would have to manually dial-in new furnace tem- peratures, forming pressures and quench-timer settings when we would change parts to be manufactured. This was time-consuming and could intro-
Fig. 5—The Dayton Parts system uses recipes, selectable using the touch- screens, to streamline production changeovers and ensure repeatability of the leaf-spring manufacturing process.
duce errors and downtime that we can’t afford.”
To tune the motion, Shortridge used the set of tools provided by Delta Com- puter Systems. One of these tools, Plot Manager, enables the designer to visu- ally and numerically compare an axis’ desired motion trajectory with the actu- al motion profile observed in a test run. With this visibility, control-loop parameter gains can be tweaked and the system re-run until the target and actual positions overlap on the plot, showing that the system is perfectly tuned.
“Without the new motion con- trollers and the accurate hydraulic pro- portional control they provide,” says Garcia, “this project would have been a lot more difficult to implement.” MF
SERVO TECHNOLOGY
INFINITE VARIABILITY— FINITE PRECISION
JIER North America, www.jier-na.com, Plymouth, MI USA, 734-404-6751 JIER Machine-Tool Group, www.jiermt.com, Jinan, China, 86-531-81616654
MetalForming/March 2015 23
