Page 45 - MetalForming March 2015
P. 45
Press Controls For All Presses
One Source
One Solution
Toledo Integrated Systems
Press Pilot 150 Control
We Provide Solutions For...
Mechanical Presses Hydraulic Presses Forging Presses Transfer Presses
Maximizer TPC (Total Press Control)
Toledo Integrated Systems Toledo Transducers, Inc.
www.ToledoIntegratedSystems.com 800-T-Toledo 419-867-4170
Tooling by Design
Toolroom Inspection
After completing die tryout, per- form these additional checks with the die open in the toolroom:
• Have any of the punches or any of the die sections been shimmed? If so, why?
• Do the pins and bushings show wear or score lines?
• Make sure it’s easy to release the stripper shoulder bolts and remove the strippers.
• Bluing the punches should reveal any punch-to-die interference.
• Remove all of the springs and care- fully check that the stripper can bottom without any interference or resistance.
• Spot-check punches and dies for proper Rockwell hardness.
• Check that every lifter and shred- der spring exhibits even pressure. Are the springs long enough to prevent premature failure due to fatigue?
• How many slugs are retained in the die bushings and die sections? Typ- ically there should be no more than three slugs, four maximum.
• Inspect all wear plates—surfaces should be smooth, not scored. Pay par- ticular attention to wear patterns that appear on one side only, indicating misalignment or uneven pressure from incorrectly set heel blocks.
• Welding and shimming sometimes are unavoidable, but they should not be present in critical areas. Workmanship for any welding or shimming should be high quality.
• Observe how the die components are reassembled. Toolmakers never should have to tighten screws using a pipe over a wrench. Fasteners are designed to function at specific clamp loads. A torque wrench is always required to ensure use of proper clamp- ing loads for each fastener.
If tool and die quality is important to you and your stamping operation, your die acceptance criteria must extend well beyond requiring your tool sup- pliers to produce parts to print or meet run-at-rate criteria. MF
sign • New & Used • Parts & Supplies • 24/7 Service • Process Training • Repairs • Control Upgrades • Water Chillers
Resistance Welding M
Ma
ac
ch
hi
in
ne
er
ry
y•
•S
St
ta
an
nd
da
ar
rd
d&
&S
Sp
pe
ec
ci
ia
al
lD
De
es
s
DIVERSE CONSUMABLES INVENTORY
STANDARD & SPECIAL DESIGN RESISTANCE WELDERS
Helping customers succeed with resistance welding for 50 years
www.tjsnow.com | 1-800-NOW-SNOW | welders@tjsnow.com
off the
Hot Press
Your daily source for
news of the metalforming industry
MetalForming/March 2015 43
